99 Cobra 4.6 Oil Cooler machined hole porting Oil?
Old September 15th, 2007, 09:13 PM   #1
ocJB3 is on a distinguished road
My 1999 Cobra SVT 4.6, 32 Valve, has what appears to be a machined hole about three-fifths of the way from the oil filter to the engine block that is suddenly porting oil (lots of oil).
I talked to two dealer shops and they haven't a clue. They didn't even know there was a hole.
Have any of you heard or seen this condition. Is this a bypass or seal relief?
I could not find the hole in any diagrams. Is it a simple bolt-on replacement to change oil coolers?
...J
Old September 15th, 2007, 09:40 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
welcome to the forums.
so your saying that this hole is machined drilled into your block?
Old September 15th, 2007, 10:20 PM   #3
Thank you for the welcome.
No...
The oil cooler.
About 3/5 of the way from the oil filter in toward the block side of the oil cooler.
Sorry, I wasn't clear about that in the initial post and couldn't edit when I got back.
...J
Old January 3rd, 2011, 07:31 PM   #4
99 Cobra Vert and an 87GT
87fordgt is on a distinguished road
You're not the only one! I just bought a 99 cobra and I have the same problem all of the sudden. Squirts oil directly down to the ground. Makes on helluva mess. I patched it with a fuel tank repair kit and that lasted about a minute! I bought JB weld, but I think I'm going to break down and take it off and drill/tap it and use a rubber washer to make sure it doesn't blow out again on me. All I can figure is it is a fluke casting issue with that part.
Threads Similar to: 99 Cobra 4.6 Oil Cooler machined hole porting Oil?
CAI Has Hole 04DSGV6 V6 Mustangs 21 November 14th, 2007 12:33 AM
Firewall Hole? mixedbreed02gt Audio/Video 3 October 28th, 2007 01:33 AM
97 Cobra, Oil leak in spark plug hole acobraman 96-98 3 October 20th, 2007 03:40 PM
Im outta my HOLE G.T. Rags The Clubhouse 7 July 10th, 2007 02:39 PM
Bung Hole? Stangzilla 5.0 Mustangs 8 April 19th, 2007 01:01 AM
