Discussing Compression ratio w/supercharger in the 99-04 Forum. I am looking at building my engine this winter/spring, and was looking at also ...
Old September 16th, 2007, 12:04 PM   #1
2002 Chevrolet Impala
I am looking at building my engine this winter/spring, and was looking at also getting a stroker billet kit (along with a bunch of other goodies!)on VT's website. The lowest compression ratio I can find on there is 9.5:1. Is that low enough for a supercharger, cause I've always heard 8.5-9.0 is ideal for a supercharger.
Old September 16th, 2007, 12:44 PM   #2
drgnracin72's Avatar
2000 mustang GT
11.79@125
what kind of supercharger are you going to run. 9.5 with a centrifugal blower will be perfect, you dont want low compression with them, as for turbo and twin screw though, youll want 8.5-9.0 with them
if i had a cobra R, i'd take out the vents and put little miniature fish tanks in their places and fill them with sea monkeys
Old September 16th, 2007, 12:47 PM   #3
I was planning on a KB. So is 9.5:1 too high with a KB then???
Old September 16th, 2007, 12:48 PM   #4
2000 mustang GT
11.79@125
yeah youd be better off going with 8.5, a stage 2 head plus a 18-20 cc dish in the pistons should do plenty to get that compression down low enough.
Old September 16th, 2007, 12:50 PM   #5
MustangMatt96GT's Avatar
13.582@97.59 @ 5800 FT
not optumal. You could put SVO heads on there that would have a NPI size combustion chamber and get down less than 9.0:1 but that for the heads and intake is like 3 grand by them selfs! You could also just keep the stock stroke with forged rods, crank, and dished pistons that would make it optimal!
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Old September 16th, 2007, 01:01 PM   #6
2000 mustang GT
11.79@125
i think you should do the higer compression, with the centri blower, till make more top en power (where you want it) and it will make for a faster car. kb are over rated and are a band aid for low compression. stick with the centri if ya want a faster car.
Old September 16th, 2007, 01:16 PM   #7
I was planning on getting VT stage 2 heads, crower stage 2 or 3 (haven't decided yet) blower cam, crower springs and retainers (titanium), I was also thinking about crower valves (any recommendations would be nice).
Also what the difference between 44.5mm and 45.5mm (+1mm), and 36mm and 37mm (+1mm)???
Any recommendations on stroker rotating assemblies??? I would prefer billet because it is stronger. Eventually I plan on making a ton a power (700+ rwhp).
Old September 16th, 2007, 01:18 PM   #8
2000 mustang GT
11.79@125
if thats the power your wanting, regular forged parts will be fine. bllet stuff is needed if your wanting over 1000
Old September 16th, 2007, 01:19 PM   #9
2000 mustang GT
11.79@125
what are these numbers for?
Old September 16th, 2007, 01:22 PM   #10
Sorry, it's for the valves...
http://www.vtengines.com/store/index...roducts_id=110
http://www.vtengines.com/store/index...roducts_id=111
http://www.vtengines.com/store/index...roducts_id=108
http://www.vtengines.com/store/index...roducts_id=109
Old September 16th, 2007, 01:23 PM   #11
Those are for the size of the valves. And it might help you out with a blower, but they are expensive to gain only 20 HP tops. And well dont buy the crower stuff from VT I orders the titanuium valvesprings and retianers Aug 17, 2007 and have yet to recieve anything. They keep blameing it on crower. But havent offered me a refund or a discount or anything.
And dude im telling you go the centri way!
Old September 16th, 2007, 01:28 PM   #12
2000 mustang GT
11.79@125
centri si the way, just go with whatever valves come in the head, theyve been researhed and proven to work fine with the combo. i wont ever order form vt again, i had problems when i ordered my heads from them
Old September 16th, 2007, 01:34 PM   #13
If I get something besides a KB it will be a TT setup. What is an ideal TT compression ratio???
Old September 16th, 2007, 01:37 PM   #14
2000 mustang GT
11.79@125
Old September 16th, 2007, 01:39 PM   #15
8.5-9.0
So, any suggestions on a good rotating assembly that will put me at 8.5-9.0? Or would it be easier to purchase the parts seperately?
Old September 16th, 2007, 01:42 PM   #16
2000 mustang GT
11.79@125
anything with a dish around 15 or bigger, with a bigger head will put you real close to what your wanting. im running a 21cc dish piston with vt stage 2 heads and i am right around 8.5:1
Old September 16th, 2007, 01:56 PM   #17
Thanks! Now this may be a dumb question but, are blower cams also good for turbos, or not? If not, who makes a good turbo cam???
Another dumb question but, how does having a bigger head lower compression?
Old September 16th, 2007, 02:04 PM   #18
Bigger Combustion chamber in the head lowers compression. There is more space to combust in.
Old September 16th, 2007, 02:09 PM   #19
2000 mustang GT
11.79@125
a blower cam isnc ompletely different form a turbo cam, i would contact a place like vt or some place that will custom build a turbo cam for you
Old September 16th, 2007, 02:10 PM   #20
Right on, thanks guys! I love this forum!
Threads Similar to: Compression ratio w/supercharger
Compression Ratio itschristorres8 Engine 22 December 1st, 2007 01:46 PM
Compression Ratio scxc15 Modular Mustangs 4 September 24th, 2007 11:01 PM
compression ratio mustangrebuilder Classic Mustangs 13 August 14th, 2007 10:08 PM
compression ratio for 93' 5.0 V8 w/ modifications kelbry Engine 4 May 10th, 2007 10:37 PM
96 gt compression ratio 96_gt_stanger 96-98 3 March 2nd, 2007 11:52 PM
