Discussing motor with 100k+ in the 99-04 Forum. I have a 2001 mustang gt 5 speed. It has 105k miles on it but ...
Old September 16th, 2007, 02:23 PM   #1
motor with 100k+
I have a 2001 mustang gt 5 speed. It has 105k miles on it but still runs perfect. I was going to put vt stage 2 heads and cams along with a stroker kit from them on my motor. Question is should i just save up and do this to a mach 1 motor because i have that option if i wait...or would the motor i have now hold up to this as long as i replace the springs and anything else that need to be replaced.......im not sure what all would need to be replaced so please help me out.
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old September 16th, 2007, 02:25 PM   #2
Slayer of Douchebags
Drgnracin72's Avatar
mustangless
youll be fine, no reason to go to the 4v motorless your wanting to make a ton of power. the mach motor can only handle the same power as the gt motor can stock for stock, but it has a lot more potential.
your motor will be fine as long as you replace the valve springs
NUKE THE UNBORN GAY BABY WHALES FOR JESUS
Old September 16th, 2007, 02:25 PM   #3
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
you could do it just fine with your GT motor.
I would wait if you have the chance to get a Mach motor though
Old September 16th, 2007, 03:58 PM   #4
the gt motor will hold up though... ive heard mixed things but like what all would need to be replaced. Im getting the new heads and cams along with the stroker so would all i need is just new springs?
1965 Mustang
Old September 16th, 2007, 05:26 PM   #5
neckbonekat's Avatar
If the option is available to you I would build the Mach 1 motor until you kill the 2V. By then you should have saved enough money to make the 4V forged with all the goodies. After that all you have to do is throw a serious boost of nitrous on it, SC or even a turbo if you can afford it. This way if the 2V dies on you you'll already have a better built back up ready to go.
2001 BULLITT GT
I DON'T CARE WHERE THE CAR IS MADE. IF YOU CAN'T BEAT IT DON'T TALK SH*T!
Old September 16th, 2007, 05:40 PM   #6
superbeef1000's Avatar
+1000
Old September 16th, 2007, 10:16 PM   #7
WAR-PARTY's Avatar
2001 YUGO GT
First the DOHC motor just has that more to brake. You have a well seasoned bolck so go with it. I tore mine down 99K SOHC and it miked out to factory specs! Do get it blue printed and add some forged stuff and a good blancing job. It's the starting point of any good motor!
Military Crew
Golden Shellback
U.S. Navy ret.
Been around the world 17 times, seen everything from a Cat fornicating contest to an elephant jack off. When Jesus has a question God tells him 'Go ask the Chief.'
Old September 16th, 2007, 10:41 PM   #8
Eagle2000GT's Avatar
Why tear down the motor? Supercharge it and run it till it needs rebuilt.
latest tune: 370 rwhp/377 rwtq
Garage: http://www.moddedmustangs.com/forums...-member-11329/
Previously Owned:
1966 Coronet 500, 426 ci est. 290-300 rwhp
1969 Camaro RS/SS, 350 ci est. 210-220 rwhp
Today is the real muscle car era.
Old September 17th, 2007, 03:43 PM   #9
other then the heads cams and stroker kit, what other forged internals would be good to buy...i want to make this motor like new so let me know everything.
1965 Mustang
Old September 18th, 2007, 08:04 PM   #10
invisa stang's Avatar
1992 mustang lx notch
one thing is that the only thing i like better about the 2v motors over the 4v is that the 2v is more responsive but the 4v creates more power then the 2v
also the mach 1 motor is the same exact motor as the cobra motor just its natualy asparated and its not hand built
but what i would do is i would just throw on a kb on your 2v and just beat the balls out of it till it broke then i would fix what broke and do it again but thats just me
www.myspace.com/lifeisasboringasdeath
rides
1987 ford F-350 XLT Lariat 7.3L idi diesel
projects
1979 ford F-350 custom (soon to get 7.3Lidi diesel)
Old September 18th, 2007, 09:30 PM   #11
02StangGToWNEr's Avatar
2006 Mustang GT
+1
Drive the 2V until it dies, then go on to the 4V.
Threads Similar to: motor with 100k+
nos on motor with 100k joejoe8455 99-04 19 August 29th, 2007 01:38 PM
Im coming up on 100k GatoStang V6 Mustangs 14 July 20th, 2007 08:21 AM
need some help american motor to import motor wadepetersen V6 Mustangs 29 May 30th, 2007 10:26 AM
what to do in 100k...maintance? El_Cangri V6 Mustangs 8 April 29th, 2007 11:17 PM
Almost at 100k Miles! dsavercool The Clubhouse 15 February 25th, 2007 11:09 PM
