Discussing Forged Crank? in the 99-04 Forum. So some of you guys might have heard that my motor took a dump on ...
Old September 16th, 2007, 07:22 PM   #1
Resident Bubblehead
00vabchgt's Avatar
Forged Crank?
So some of you guys might have heard that my motor took a dump on Wednesday. Rick (Twist2go) has the car up at the shop. I went there on Saturday and Rick showed me the chunks of what used to be one of my rod bearings. I'll post up some pics when i get the chance. so, since i now need at least a new rotating assembly, i thought i'd ask a few questions. i'm on a tight budget, so i'm trying to be smart about this. i figure, i may as well go with forged internals now. i've been looking at a couple of VT shortblocks. the main difference between the two i'm looking at is the crankshaft. one's forged, and the other's not. i do plan on going FI on the motor further down the road and i'd like to not have to replace the crank later on for the blower. how much HP can the stock crank hold up to? it's always been my understanding that the weak link in these motors is the rods and pistons. here's the links to the shortblocks i'm looking at right now.
http://www.vtengines.com/store/index...oducts_id=1389
http://www.vtengines.com/store/index...oducts_id=1424
Thanks guys
Submariners Do It Deeper
Military Crew
MM1 (SS)
Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old September 16th, 2007, 07:36 PM   #2
Slayer of Douchebags
Drgnracin72's Avatar
mustangless
the cast crank will handle around 600 hp so if you plan on going past that with fi go with the forged
NUKE THE UNBORN GAY BABY WHALES FOR JESUS
Old September 16th, 2007, 07:43 PM   #3
Resident Bubblehead
00vabchgt's Avatar
here's those pics
http://[img]http://i186.photobuc....jpg[/img]
Military Crew
MM1 (SS)
Bluenose
US Navy Veteran
Old September 16th, 2007, 09:48 PM   #4
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
looks like fun!
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Old September 16th, 2007, 09:50 PM   #5
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
that's just a little worn...
Old September 16th, 2007, 09:57 PM   #6
WAR-PARTY's Avatar
2001 YUGO GT
Vt has a very goog reputation, I've bought several things from them. easy to bu business with. I would call and talk with them If I was ordering a short/long block. It helps that way you both know what your buying, and what it is set up for. Forged crank, no brainer!
Military Crew
Golden Shellback
U.S. Navy ret.
Been around the world 17 times, seen everything from a Cat fornicating contest to an elephant jack off. When Jesus has a question God tells him 'Go ask the Chief.'
Old September 19th, 2007, 06:06 PM   #7
Resident Bubblehead
00vabchgt's Avatar
ok, so as far as pistons go, should i go dished or flattop? what are the advantages of each? i'm going 0.020" over on the bore, but not sure what to do about the tops.
Military Crew
MM1 (SS)
Bluenose
US Navy Veteran
Old September 19th, 2007, 07:42 PM   #8
Dished if you wanna run a supercharger or turbo later down the line, Flat top if you wanna stay N/A and make good power with out any power adders.
Dished pistons will lower your compression and will also lower the amount of HP you will make N/A but will allow you to run more boost with a turbo or supercharger and make gobs of HP
Flat top or Dome pistons will raise your compression and allow you to make more power N/A without any boost but will severly limit the amount of boost you could run on the engine if you were to go turbo or supercharged later.
Old September 19th, 2007, 08:41 PM   #9
Also depending on the cam you wanna run you would need valve releifs in the flat tops to make sure you don't have any piston to valve contact.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old September 20th, 2007, 11:24 AM   #10
Resident Bubblehead
00vabchgt's Avatar
so how deep dish should i go? options are 5cc, 11cc, 19cc and 27cc. i do plan on going FI further down the road and i want to make about 400- 500 hp with the blower.
Military Crew
MM1 (SS)
Bluenose
US Navy Veteran
Old September 20th, 2007, 12:04 PM   #11
mustangless
id say 11cc if your gonna go with a centri blower, 19, if your going roots or turbo
Old September 20th, 2007, 12:58 PM   #12
1997 Mustang GT
I'd call them, and they can tell you how much compression you will have with your set up. Id say to go wirth about 8.5-9:1 compression. Low enough to make good boost, but not so horibly low that even with a centri your car won't suck.
Old September 20th, 2007, 02:13 PM   #13
limited's Avatar
with 19cc your compression is gonna be about 9.2,good for a centri car. for a twin screw you will want the 27 cc which puts at 8.5 or so. because the twin screws don't need the extra low end power the higher compression gives you.go with the forged crank option,comes with better parts and also comes with oil pump
99 limited edition conv. KB 2.1 9 psi intercooled.vt stage 3 blower cams,gt40 fp/bap,vt covers,frpp 3:73's,demolet cai,accufab 75mm tb,Sct Ba 2400,tri-ax,bfg kdw's,magnaflows
Tuned by Joe at http://www.tricktuners.com
Old October 2nd, 2007, 04:14 PM   #14
Resident Bubblehead
00vabchgt's Avatar
quick update on the car situation. last monday i ordered a forged rotating assembly from VT. here it is:
http://www.vtengines.com/store/index...oducts_id=1333
I went with the 19cc dish pistons since i plan to throw a centri on the car. pistons are 0.020" overbore. Problem is, they haven't shipped yet. i understand that this has been an ongoing problem with VT, and i'm sure they make a great product, but damn. i know i'm not the most patient guy, but i want to drive my damn car!
Military Crew
MM1 (SS)
Bluenose
US Navy Veteran
Threads Similar to: Forged Crank?
Crank but no Spark. noyz25 5.0 Mustangs 5 July 23rd, 2007 10:59 PM
351w with a 302 crank? 68351w Classic Mustangs 4 July 4th, 2007 01:29 PM
crank pulley mikedoogen Modular Mustangs 3 June 20th, 2007 02:22 AM
crank pulley help mikedoogen 2005+ 3 June 19th, 2007 02:17 PM
crank ? 86gt5liter 5.0 Mustangs 3 December 14th, 2006 07:14 PM
