please help me 4.6 sohc gt
Old September 16th, 2007, 10:00 PM   #1
natedawgishot's Avatar
natedawgishot is on a distinguished road
i have a 2000 gt mustang that is smoking bad very bad. a few months ago i blew a rod bearing and so i put in a new lower end. now just about a month later it is smoking bad and i dont know what it is. could it be the rings? but i never touched those i only replaced the crankshaft and bearings. it doesnt have the power that it used to and the smoke is white? im broke as a joke so do u have any ideas? i cant afford a new motor.any ideas
Old September 16th, 2007, 10:03 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
white smoke...
hmm.. check your coolant
you might need a new head gasket.
Old September 16th, 2007, 10:24 PM   #3
im losing oil as well and there is a lot of smoke could it be a ring? can a gasket smoke that much?
2000 gt convert and a 2001 v6
Old September 16th, 2007, 10:26 PM   #4
HMUSN's Avatar
iTrader: 9 reviews
white smoke normally indicated a head gasket/ low coolant.
black smoke normally indicates burning oil.
if you have a bad head gasket it will smoke an assload under WOT.
Old September 16th, 2007, 10:29 PM   #5
brianm's Avatar
2011 ram 1500 hemi
brianm will become famous soon enoughbrianm will become famous soon enough
its probally a ring, but you never know.good luck
vmp500 hp. jba lts. powerhouse d/s Sold
Old September 16th, 2007, 10:30 PM   #6
thank u so much i never thought about that. how much do they run do u know?
Old September 16th, 2007, 10:32 PM   #7
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Double check your oil. I blew a head gasket on a old Dodge once. I ended up with anti-freeze in the oil. Not good.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old September 16th, 2007, 10:33 PM   #8
i hope its not a ring.how could it be if i never touched them?
Old September 16th, 2007, 10:35 PM   #9
im losing a small amount of oil. it smoked a small amount at first and then got worse and worse now i cant even drive it
Old September 16th, 2007, 10:57 PM   #10
how much would it cost to have a pro to change the gasket
Old September 17th, 2007, 12:22 AM   #11
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
from the sounds of it i think you may have blown an oil ring and a rod bearing at the same time.. i'd definately get it looked at and get a compression test done.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old September 17th, 2007, 03:52 AM   #12
jivepepper's Avatar
jivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the rough
Need to do a compression check.
2000 GT 665/540rwhp/rwtq
Best 1/4:
AT 431HP 12.29 @ 124
AT 515HP 11.24 @ 129
AT 638HP 11.01 @ 135
AT 665HP ??.?? @ ???
80*+day, 1400' track, 10.5" DD Cobra R's & 315/35/17DR'S
Trap speed = true measurement of HP.
Old September 17th, 2007, 11:38 PM   #13
zach99gt is on a distinguished road
if it is a head gasket the smoke will smell like antifreeze and it will over heat.
Old September 18th, 2007, 10:07 AM   #14
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
[quote="HMUSN"]white smoke normally indicated a head gasket/ low coolant.
/quote]
White smoke is oil black smoke is an over rich mixture. Check your oil if it is milky gray you losing coolent into the oil pan. you can warm up the car ease the coolant cap off re start the car if it is bubbling up in the over flow tank you blew a head gasket. You can also go to a repair shop and they can put a gauge on the coolant tank and tell if you putting gas or ehsaust into the coolant tank. Good luck
Old September 18th, 2007, 07:58 PM   #15
invisa stang's Avatar
1992 mustang lx notch
invisa stang is on a distinguished road
Send a message via AIM to invisa stang
actually oil is like a white blue mix in the smoke and white is coolant getting into the cylinders but Bob17830 is right you wanna do a compression test if it shows low compression that will explain why you are losing that power
[rides
1987 ford F-350 XLT Lariat 7.3L idi diesel
projects
1979 ford F-350 custom (soon to get 7.3Lidi diesel)
1992 ford mustang notch (just shell soon to get engine and drive train hopefully)
Old September 19th, 2007, 12:11 AM   #16
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
Originally Posted by HMUSN
white smoke...
i was about to say the same thing
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Old October 15th, 2011, 08:32 PM   #17
Look Ma! My First Post!
12.82@108.46
Mustang Josh is on a distinguished road
Re: Smoke??!!
Okay so explain this one.... my GT does the same thing but only after it's warm and it sits at idle a min or two and you take off abruptly it smokes pretty good. It's not carbon, i wish! Rather it's oil because it uses oil. I ran compression on the bastard and oddly enough cyl's 5-8 were at 172-176lbs and 1-4 as follows, 168/165/142/137. It's not losing coolant or running hot or even badly persay; it does not feel like it's lost power, or maybe it has because it's been like this so long maybe I don't notice? I am thinking damaged/cracked/broken ring(s). Thoughts???
Threads Similar to: please help me 4.6 sohc gt
sohc to dohc usmc513 96-98 3 October 30th, 2007 05:59 PM
SOHC to DOHC energiesource 99-04 9 May 16th, 2007 11:06 AM
V8 4.6 SOHC The eaglenator General Tech 6 October 10th, 2006 12:17 AM
