Discussing gear grinding in the 99-04 Forum. ive noticed lately that at random times my car will grind into any given gear...... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2001 Mustang Gt
gear grinding
ive noticed lately that at random times my car will grind into any given gear...today it was grinding into 4th no matter what id do and sometimes the same happens with 5th, i have an early 01 GT and if im not mistaken its a T45...if anybody has any ideas what that might be let me know...it also feels like its hard to get into gear sometimes too and just makes all kinds of knocking sounds and shit...ive never driven another mustang before so idk if thats just how these cars are or what
Garage: http://www.moddedmustangs.com/forums...e-member-9480/ |
Master of the Force
Millenium Falcon
"Just Living the Dream"
sounds like ur synchros may be shot
MSO smokes pole |
91 Sonic Blue Goodness
19.83 @ 12mph
:homo
and you have either the t-45 or the t-3650 depending on when your car was built in 2001 |
2001 Mustang Gt
i was afraid of that...
2006 Mustang GT
Yea I believe you have the T-45 if it's an early 01. And I agree with the other guys, your synchros are probably shot.
2001 Mustang GT
the speed of smell
if its not the synchros it could be a bent shift fork, since its very unlikely that ALL of your synchros went bad..
![]() '01 GT P-1SC 383rwhp, 380rwtq 2003 Rubicon (DD) 05 Suzuki SV650S 55mpg moddedmustang's drunk story teller www.myspace.com/jeepwheelerbob |
Master of the Force
Millenium Falcon
he only mentioned 4th n 5th
MSO smokes pole |
2001 Mustang Gt
could that have something to do with my tri-ax? its mostly 4th and 5th that it grinds it but all the gears are kindof hard to get into most of the time
19.83 @ 12mph
depends.
is the shifter brand new? and if you have the t-3650... did you pull the shift stops out of the shifter? |
2001 Mustang GT
the speed of smell
he said any given gear though.. the tri ax is definately a stiff shifter, that could be what it is. is it actually grinding or just kinda popping into gear hard? cause that is a stiff tranny and a stiff shifter
2001 Mustang Gt
its the t45 im like 95% sure so i set the stops and the shifter is about 4 months old so its not too old and it actually grinds into mostly 4th and 5th...the others it just goes into gear really hard
Master of the Force
Millenium Falcon
ur right.....my bad.
my friend had issues with his tri ax for the first 3 months of having it. Nothing Grinding, just had to give it a little more oomf in his shifts. My other friend took the car for a spin and even had trouble power shifting with it. also, what kind of condidtion is ur clutch in?
MSO smokes pole |
2001 Mustang Gt
might seem like a noob question but how exactly could i tell if my clutch is going bad
19.83 @ 12mph
it will start slipping.
harder to get into gear harder to stay in gear.. |
Master of the Force
Millenium Falcon
throw out bearing whistling or humming....
real hi clutch release point. sometimes when u try to move in first it feels almost like the car isn't catching gear right away edit: damnit doc. u beat me
MSO smokes pole |
2001 Mustang Gt
nah my clutch is good then
#18 | |
2006 Mustang GT
+1 And I have even had cars stall out on me occassionaly when the clutch was starting to go. |
2006 Mustang GT
Maybe you could record the grinding sound for us somehow, that way we can better determine the problem.
2001 Mustang Gt
hmm...i can try..im in school right now so itll be a little before i can get home but ill definately see what i can do. but i mean its really not ALL the time...its only at random times it happens and then itll happen for the next 5 or 6 times ill put it in that gear and then go away
Threads Similar to: gear grinding
| Grinding after the track | weems | 99-04 | 58 | July 13th, 2007 08:37 AM |
| t5 grinding in reverse | tayboo24 | 5.0 Mustangs | 19 | June 4th, 2007 01:20 AM |
| 1st gear grinding | Luis_GT | 2005+ | 9 | April 4th, 2007 08:05 AM |
| Gear Grinding... | jerb43 | 96-98 | 18 | October 31st, 2006 08:19 PM |
| tranny grinding | terribleonexx88 | 5.0 Mustangs | 12 | October 19th, 2006 12:13 AM |
