13.6@100.38mph,(before tune)@3300ft elevation
track prep
what general maintenance can i do to prep my car for the track.
48.47@ 12.58
just make sure everything is clean and not leaking.
lower your tire pressure in the back a bit/
So like my air filter and what not and is there a way to clean spark plugs?
Mac LT'S,BBK CAI,BBK Throttle body.trick flow plenum,1inch throttlebody and plenum spacers 75mm,95mm maf,underdrive pulleys,4.10 gears,King cobra clutch,t56 transmission,pro 5.0 short shifter,aluminum cobra driveshaft |
48.47@ 12.58
your looking for a tune up or racing prep?
and just replace your plugs.
Prety much both.
48.47@ 12.58
ok.
plugs plug wires oil oil filter air filter transmission flush top off your fluids maybe a coolant flush sea foam it. and you should be good to go.
my plugs are only 2 months old.i just want to do everything i can to prep my car
aight thanks!!!!!
48.47@ 12.58
well that's the list.
umm.. get Drag Radials.. weight reduction
im running 315/35/17 sumitomos at the moment.but i have 285/45/18 perellis sitting in th e garage what should i run with at the track
ordinarily i cant get the perellis to hook up until 3rd gear.but im wondering if i heat them up if they would stick.my 315 stick great.its just that i dont want to burn those up if i dont have to
get ya some used cheap full slicks on dookie rims...and keep ya good tires for the street...and unhook your front sway bar..it'll help the weight transfer better with the slicks...and if ya want it to bit hard outta the hole...drop ya psi in them slicks down to 10...10 is the magic number...ive went as low as 6psi...but it gets a lil squrrly on the big end...
if ya running street tires @ the drag strip.avoid going into the water box if ya can...some tracks you got to drive through it...if ya do just clean ya tires off...1sec. burnout is all ya need to do with street tires...if ya get'em hot they'll be slicker than hell...ride ya clutch out of the hole...get that down pat...it'll work for ya
#14 | |
2001 YUGO GT
i changed all my fluids.everything is now Royal Purple.engine,trans and rear end all changed.im gonna sea foam it this weekend.
Threads Similar to: track prep
| Supercharger prep | fastpony | V6 Mustangs | 10 | July 25th, 2007 05:41 PM |
| ran the track | ttop5.0 | Drag | 8 | March 7th, 2007 08:02 PM |
| my first day at the track | 02steedagt | 99-04 | 14 | March 6th, 2007 08:47 AM |
| Never too it to the track yet! | dmachine22 | Modular Mustangs | 21 | January 30th, 2007 07:35 PM |
| new motor prep nitrous/piston question | 173speed | 5.0 Mustangs | 11 | October 12th, 2005 11:37 PM |
