Discussing KB Twin Screw in the 99-04 Forum. I am running stock internals and thinking about doing a Twin Screw. how much boost ...
Old September 22nd, 2007, 02:54 PM   #1
Dawgfude03GT's Avatar
KB Twin Screw
I am running stock internals and thinking about doing a Twin Screw. how much boost could I run safely? Also I don't wanna blow out my rear end. Would 4:10 still be a good fit for gears?
Old September 22nd, 2007, 02:55 PM   #2
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
3:73's if you plan on a twin screw.
keep it at around 9 psi and TUNE. a tune is your best friend.
keep it under 400rwhp and you will be fine.
Old September 22nd, 2007, 03:02 PM   #3
what if I go over 400 HP should I swap out ther rear?
Old September 22nd, 2007, 03:03 PM   #4
HMUSN's Avatar
19.83 @ 12mph
nah.. just don't launch on drag radials all the time.
besides if you do break it that just means it's time to upgrade
Old September 22nd, 2007, 03:07 PM   #5
MuchCoolerThanGTsetGO
ChrisJ's Avatar
SLOW
Keep the power under 400rwhp as said before...
But also as said before a tune is the key to the puzzle...Without a good tune you will blow the engine...
The rear end will hold up as long as you dont hit the track to much with it...Drag Radials will kill the rear end...
My Junk
www.myspace.com/cjobe
Old September 22nd, 2007, 03:14 PM   #6
yeah I don't plan on throwing those on. its a dailey driver during the summer Ijust want some more getup and blow the doors off any rice rockets that try to step! :-D :award
Old September 22nd, 2007, 03:14 PM   #7
ChrisJ's Avatar
SLOW
Then a KB 2.1 would work just fine...Buy the intercooled version for even more safety...
My Junk
Old September 22nd, 2007, 03:15 PM   #8
Where iss at?
weems's Avatar
2003 Mustang Mach 1
12.89@104.6
you should have no problem doing that with a kb
Beautiful
Old September 22nd, 2007, 03:24 PM   #9
you dont think 9 psi is too much? or shouold I stick around 6-7?
Old September 22nd, 2007, 03:25 PM   #10
ChrisJ's Avatar
SLOW
9psi is just fine with a good tune...
My Junk
Old September 22nd, 2007, 03:25 PM   #11
HMUSN's Avatar
19.83 @ 12mph
9psi is fine as long as your tune it on point.
it's all about the tune man.
edit: dammit chris ya beat me.
Old September 22nd, 2007, 03:27 PM   #12
@ 9 psi it adds approx 160 HP which throws a stock GT to 420. I have cold air intake and cat back exhaust and throttle body nd upper plenum so that would prolly put me somewhere near 440 ish so then should I stick to 6 PSI? or even 7?
Old September 22nd, 2007, 03:27 PM   #13
ok.
Old September 22nd, 2007, 03:43 PM   #14
invisa stang's Avatar
1992 mustang lx notch
ehh on my fathers car he put a kb on with 11lbs of boost with cold air, bigger throttle body, and exhaust and his car runs just fine
Old September 22nd, 2007, 03:46 PM   #15
HMUSN's Avatar
19.83 @ 12mph
that because he has an on point tune.
an 11psi KB is pushing it on a 2v.
Old September 22nd, 2007, 05:27 PM   #16
RC02GT's Avatar
whats about the pricing for KB 99-04 GTs intercooled? there site doesnt work
BBK CAI, BBK shortys, BBK x pipe, Flow's, MGW shifter
Old September 22nd, 2007, 05:28 PM   #17
Fryrice's Avatar
Why do people ask for advice and then argue with it ?
invisa stang , what does you dad drive ?I can run 20lbs on my motor but that doesnt mean its a good idea .
Fryrice has left the building.
Old September 22nd, 2007, 06:33 PM   #18
he drives a 04 gt
www.myspace.com/lifeisasboringasdeath
rides
1987 ford F-350 XLT Lariat 7.3L idi diesel
projects
1979 ford F-350 custom (soon to get 7.3Lidi diesel)
Old September 22nd, 2007, 06:56 PM   #19
twin screw intercooled is 4999.00
Old September 22nd, 2007, 06:57 PM   #20
I've got a 75mm throttle body and an upper plenum is that the best bet for the twin screw?
Threads Similar to: KB Twin Screw
Fastest 3v Twin Screw 05 gt KBpowered05GT 2005+ 4 November 4th, 2007 11:03 PM
twin screw max hp? energiesource 99-04 6 October 5th, 2007 12:35 AM
Centi or Twin-Screw? RandoGT 96-98 18 June 19th, 2007 03:02 PM
Twin Screw v. Centrifugal GTSilver 99-04 6 November 15th, 2006 03:21 AM
twin screw? GTSilver 99-04 3 August 30th, 2006 08:02 PM
