Procharger belt rip
Old September 24th, 2007, 05:36 PM   #1
02Gt Stang's Avatar
13.6@102
02Gt Stang is on a distinguished road
Procharger belt rip
I was supposed to go in for a new tune from my tuner last friday, got on the dyno... belt slipped. CAme home and replaced the belt with the supplied 108 inch belt, its a bitch to get on def need three people for this, anyways car runs good way better than before, get it rebooked for wednesday on my way home from school today i noticed a slight sift type sound i stopped popped the hood and my belt has a small rip in it on the side furthest away from the engine block. Anyways im home right now and i think the cause is that my tensioner is pretty maxed out and when i looked down the belt looks liek it is rubbing on metal under the tensioner. Just wondering if anyone knows about grinding down the tensioner if this stops this from happening? I got a new 108 belt again and i cant find anything on google or what not about fixing this issue anyone had the same problem?? damn procharger wish id just save up for a hellion turbo kit.
Old September 24th, 2007, 06:00 PM   #2
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
sometimes the tensioner can go bad, or there is a misalignmentwith the procharger idler pulley
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old September 24th, 2007, 06:04 PM   #3
02Gt Stang's Avatar
13.6@102
What do you mean by go bad? the pulley alignment looks good. BUt the tensioner doesnt have any visible flaws to it that i can see.
Procharged 383 rwhp/ 391 rwtq
Old September 24th, 2007, 06:07 PM   #4
02Gt Stang's Avatar
13.6@102
hhaha the panty dropper!! I'm going to just take everythign apart up front and see if i can tell exactly where the belt is rubbing, from what i can see now though is that it looks like its rubbing along the bottom of the tensioner, like the pivot point or fulcrum haha not sure what that part is called but yeah the belt is def. up against it.
Old September 25th, 2007, 05:55 PM   #5
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
Sounds like its not aligned correctly.
Bolt on list in Garage..
Old September 25th, 2007, 06:56 PM   #6
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
I also think it's not aligned well?
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old September 25th, 2007, 10:07 PM   #7
gsjohnson is on a distinguished road
Do you have the supplied Procharger spacer that goes between the timing cover & the bracket installed? That is critical for the correct pulley alignment. Second, is the supplied bolt stopper adjuster stud with the jam nut adjusted up against the bracket? If it is not, it will cause the bracket to flex under load, thus creating a belt alignment issue as well. This is especially true if you are heavy footed wanting to experience that sexual feeling with all that irresistable power at the tip of your toes on a more than regular basis. And finally, if your belt tensioner has more than 15,000 miles on it, you should replace it. They become weak and won't hold the belt tight. In fact, the Procharger instruction manuel states to replace the tensioner with a new unit when installing the blower. Additionally, the tensioner should be replaced every 10 to 15 thousand miles ther after. The Procharger is a good quality unit, but you have to pay attention to the details if you want it to last & operate as designed. Certainly better than sex when operating as it should.... Hope this helps.
Old September 26th, 2007, 05:07 PM   #8
Blivit is on a distinguished road
I had something similar happen to me on my 01 with a P1SC. Check the procharger idler pulley (the one that goes between the bracket and the alternator. The bearings gradually failed on mine causing the belt to create a ridge on the pulley (pulley should be smooth) and this ridge would eventually rip the belt up. It took me 3-4 belt deaths before I finally figured it out. Ordered a new pulley from procharger and so far it's been fine.
Old September 26th, 2007, 05:34 PM   #9
03 Mustang GT Twin Turbo
10.43 @ 139mph
WAVEBYE is on a distinguished road
Send a message via AIM to WAVEBYE
my tensioner locked up on me at about the 1000' mark when i was making a pass. i only found bits and pieces of it under the hood after i got back to the pits. needless to say it was the end of the night for me.
but yeah i've heard of that happening alot with S/C SN-95s.
Nobody gonna take my car
Im gonna race it to the ground
Nobody gonna beat my car
Its gonna break the speed of sound
Oooh its a killing machine
Its got everything
Like a driving power big fat tires
And everything - Deep Purple
Old September 26th, 2007, 08:15 PM   #10
The Mean Green
MATT02GT's Avatar
Im up to 2 belt kills already...
Threads Similar to: Procharger belt rip
Procharger Belt Install gsjohnson 99-04 6 November 1st, 2007 10:25 PM
belt for ud pulleys gooberhead320 V6 Mustangs 6 August 4th, 2007 06:14 PM
Belt size illusionownz General Tech 0 October 20th, 2006 05:53 PM
what belt? Drgnracin72 General Tech 0 June 23rd, 2006 02:58 AM
