Intake manifolds???
Is there an aftermarket intake manifold that is better than the others? I just bought the Trickflow Track Heat manifold, and just wanted to let everyone know that it is a pain to install....EGR relocation, and if you have an intake...that's another issue.
Proud American
How do u like it? I think the trick flow is the best aftermarket that is below 1000 bucks and the P-51 and logan are the best above 1500
I like it but it was just a pain to put on like I said before. The EGR valve has to be moved forward and if you don't do it just right you are S.O.L. So needless to say I ended up eliminating my EGR valve.
Proud American
Yea i plan on doing that too! I may run one of these or a P -51 or a logan next year!
Threads Similar to: Intake manifolds???
| Intake manifolds? | DCstangGT | 99-04 | 20 | September 9th, 2007 03:47 PM |
| Intake Manifolds | 97_4.6L_Stang | Modular Mustangs | 14 | January 21st, 2007 03:23 PM |
| intake manifolds............ | ERIC | 99-04 | 1 | January 21st, 2007 12:54 PM |
| intake manifolds? | sonicblue | Modular Mustangs | 5 | January 17th, 2007 04:15 PM |
| intake manifolds 94 GT | WVSNS& | 94-95 | 7 | August 31st, 2006 01:10 PM |
