2011 Mustang GT
TPS sensor
The other day I dug into my car and the traction control activated, after I let off the pedal the car ran crappy. At idle it runs fine, in neutral I can rev it and it runs fine, however once I put in gear it runs like crap. If the car is running like junk from the get go will it matter if I disconnect the TPS sensor? Cause if I do (disconnect it) it runs just the same. Could the be a sign of a bad TPS?
![]() 2011 5.0 1.3 gallons of American performance!! K&N drop in (I know, I'm cheap) Flowmaster American Thunder exhaust H&R Super Sport springs Bremmer BR01 19x8, 19x9.5 wheels Bottomless bottle of soap! |
2002 Gt
Not Slow
![]() iTrader: 1 reviews
i broke the spring in my tps from over tightening onto the plenum,.. it didnt make my car run any different except for the revs between shifts never really came down til i replaced it. it doesnt sound like a tps prob... is your CEL ON?
2001 Mustang SVT Cobra
I don't think it's got anything to do with the TPS. It sounds like a few possible problems. Coils (any code), plugs (could be going), injectors (clogged, how low did it go on fuel when you stepped on it?) Vacuum line that holds the traction control module?
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
2002 Gt
Not Slow
and when you say "dug" into it does that mean heavy accel.? Cuz my car had the same problem which i just fixed yesterday,.. i was accelerating hard 1st to 2nd, and i heard/felt a jolt. I thought i busted a u joint or somethin to do wih drive line cuz the car shook and ran like kaka. Long story short it was a blown coil.
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
Threads Similar to: TPS sensor
| iat sensor? | lone5oh | 5.0 Mustangs | 15 | August 26th, 2007 05:41 PM |
| o2 sensor help | mustangrebuilder | 2005 - 2010 | 0 | June 25th, 2007 07:55 PM |
| TPS Sensor | bigbadtalontsi | 5.0 Mustangs | 0 | March 27th, 2007 08:47 PM |
| MAP sensor | ROBBED666 | 2005 - 2010 | 0 | October 9th, 2006 03:12 PM |
| MAF sensor | 5.0 Rono | 5.0 Mustangs | 2 | July 16th, 2006 08:51 PM |
