Discussing injectors in the 99-04 Forum. does anyone know what size the stock injectors are in the 2001 bullitt.... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2001 mustang bullitt
injectors
2001 bullitt3:73gears,bbk ceramic shorties,bbk xpipe,bbk 65mm tb,flowmaster catback,steeda triax. eibach springs,m&m lower control arms,ford aluminum ds,novi 2000,intercooled,gt pump,aluminum flywheel,spec clutch,mmr 900 LB,stage 2 blower cams |
91YJ 98ZJ 98P71
19 pounders
i was wondering because i was told today i would need a 42lb injector,when i run a supercharger.
i could be wrong but with a good tune you would not need that large of an injector or a bigger fuel pump if you have stock internals and running below 10lbs of boost
91YJ 98ZJ 98P71
you will need fuel upgrades.
yes that means the injectors and pump. |
i talked with a gentleman today at a dealership where i was buying
a few parts for my car,and he has a gt with stock injectors and pump running 9lbs of boost and he said he hasn't had any problems,and its been 6 months and he drives it everyday.
91YJ 98ZJ 98P71
than he is an idiot.
He is either lying or stupid and about to blow his car up. |
question then????
what is a good injector to run?
91YJ 98ZJ 98P71
what super charger do you plan to run and how much boost?
nathan from brothers talked me into a vortech,and he also told me not to exceed 10 psi with stock internals.
91YJ 98ZJ 98P71
39 pounders will do you fine than.
42's if you have a good tuner. |
thanks!!!
91YJ 98ZJ 98P71
yup..
1999 Mustang GT
Will termis 39# injectors fit on my 04 GT without any mods (connectors, etc...)?
#14 | |
Mustangless atm 2006 2500 HD Diesel. Built allison trans and other goodies
91YJ 98ZJ 98P71
no they won't.
they have different connectors. you have to buy pig tails from ford to make them work.. I ran 39's and had that issue when installing them |
#16 | |
1999 Mustang GT
me too. too bad. I found some 04 cobra's for $150... Keep looking then......
91YJ 98ZJ 98P71
I would grab the 39's at that price.
pig tales are cheap.. I think I payed around $7.00 each for mine from the Dealer. |
1999 Mustang GT
don't you think I can find straight GT's for around that price?
91YJ 98ZJ 98P71
you mean 19 pound injectors?
Threads Similar to: injectors
| Injectors | 95blackbeauty | 94-95 | 4 | November 9th, 2007 01:00 AM |
| injectors | sleezy | 96-98 | 14 | September 23rd, 2007 05:38 PM |
| 39 # injectors and stock injectors for sale | 67/07 | For Sale | 0 | September 20th, 2007 09:27 PM |
| Injectors | sn94 | 5.0 Mustangs | 19 | September 16th, 2007 11:09 PM |
| injectors 03 04 | roberbr6 | 5.0 Mustangs | 0 | December 17th, 2006 02:57 PM |
