2004 Mach1
Brake light comes on
While driving. Every happen to anybody else?
![]() iTrader: 1 reviews
which, the abs one?
i forget what they look like
2000 Mustang Gt
13.56 @ 106
are your talking about the ebrake light?
if so then check your brake fluid
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams Manley Valves/Springs - Centerforce Dual Friction BBK LT's - BBK o/r H - Bassani catback FRPP 4.10s - XCAL2 - BBK UDP's 306rwhp/333rwtq |
im pretty sure mine came on once and a while after hard braking,
2004 Mach1
Yeah the e brake light i'll check the fluid
2000 Mustang Gt
13.56 @ 106
its most likely your fluid level then.
Resident Bubblehead
i had a problem like that in my Explorer. the e brake light would come on during braking and turns. checked the fluid level in the reservoir and it was a little low. filled it with some DOT3 and the problem went away.
13.9@101
Yup its low brake fluid. Happened to me before.
![]() 13.9@101 before some mods |
2004 Mach1
Cool thanks
check your pads as well, they could be getting a little thin which could be why your fluid level is low.
Threads Similar to: Brake light comes on
| 3rd Brake Light | VSR13 | Visual | 6 | November 12th, 2007 08:09 PM |
| 3rd Brake Light | KatTuck013 | V6 Mustangs | 2 | November 12th, 2007 01:59 PM |
| 3rd Brake Light | VSR13 | The Clubhouse | 16 | November 10th, 2007 02:16 PM |
| Third brake light | ByPopularDemand | V6 Mustangs | 39 | August 3rd, 2007 01:40 PM |
| e-brake light | tprokop | General Tech | 5 | May 26th, 2006 06:31 PM |
