P1507- Idle Air Control Under Speed Error
Old September 27th, 2007, 08:13 PM   #1
warrior86's Avatar
2008 Mustang GT
warrior86 will become famous soon enough
Send a message via AIM to warrior86 Send a message via MSN to warrior86
P1507- Idle Air Control Under Speed Error.
I just bought one of them gaskets off eBay where the 2 Middle holes are cut down to the same size as the ones the bolts go into. I believe 9/32.. and it definitely did a good for my idle and everything like it was suppose to.
I decided to run a diagnostic on it, and though there were no check engine lights out or anything, my first scan tool brought it up as a potential problem, but it really didn't list it as a major problem through the software like it does other DTC's.
Then i ran another scan tool, one that was more advanced and it didn't report any errors.
I'm wondering what this is and what under speed error means.
IS IT because there is not enough air going through those small holes.. and what is the negative above not making the holes as big as the main ones in the IAC?
Threads Similar to: P1507- Idle Air Control Under Speed Error
P0506 Idle control... PLEASE HELP! msolaas1 2005 - 2010 4 May 31st, 2007 12:45 AM
speed control jonnotch 5.0 Mustangs 0 March 3rd, 2007 07:20 PM
rewiring speed control buttons on steering wheel xiiiix Audio/Video 3 February 17th, 2007 12:40 AM
answer to my p 1506 idle air overspeed error jagstang96 96-98 0 September 7th, 2006 11:54 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 04:11 AM
