P0171,P0174
Old September 28th, 2007, 09:00 AM   #1
Look Ma! My First Post!
Clay is on a distinguished road
P0171,P0174
Have the MIL eliminators,now I am getting P0171,P0174.Bank 1&2 lean.Also getting P1000,&P1AEE,which is not even a code.???
Old September 28th, 2007, 09:39 AM   #2
Blivit is on a distinguished road
What are you using to read codes?
The MIL eliminators effectively shut off the rear O2 sensors but the two codes you are getting refer to the front sensors. They are the ones that monitor your fuel trims. If those are off, these codes will the thrown.
P1000 is just an OBD systems readiness code that will go away after driving the car more. It comes on any time you flash a processor or disconnect the battery. It does not set off the check engine light.
There are P1Axx codes but most of them relate to hybrid vehicles.
Old September 28th, 2007, 02:12 PM   #3
1967 mustang coupe
ma67cpe is on a distinguished road
Send a message via Yahoo to ma67cpe
you are only supposed to put mils on the rear o2s. Did you put them on the fronts as well?
Old September 28th, 2007, 09:18 PM   #4
ujslost's Avatar
MIL eliminators do not effectively shut off the rear o2 sensors. They are a mere attempt to fool the pcm. BTW the rears are monitors not o2 sensors. p1000 is a code that means that the test was either interupted or not completed. I have no cats on my car and I do not run MIL eliminators and I dont get the lean/rich codes from this. MIL eliminators do not always work.
Old October 2nd, 2007, 05:58 PM   #5
mixedbreed02gt is on a distinguished road
Send a message via AIM to mixedbreed02gt Send a message via MSN to mixedbreed02gt Send a message via Yahoo to mixedbreed02gt
Re: P0171,P0174
i just registered these exact same 2 codes, time to replace your front oxygen sensors. mine are on order should be here tomorrow or thursday.
if you don't want a mechanic to charge you $50, i highly suggest you purchase an oxygen sensor tool so you can remove it yourself. you'll need a 22mm or 7/8" oxygen sensor socket, and has a 3/8 drive. they run about $10 - $20 plus shipping.
Threads Similar to: P0171,P0174
p0171 code 96gtponyred 96-98 7 August 24th, 2007 12:03 AM
slight misfire causing p0174 trouble code? midnightrace 99-04 3 December 11th, 2006 11:16 PM
