![]() iTrader: 1 reviews
Mach 1 or cobra? (engine, that is)
so i can get a mach 1 engine with the transmission for about 6 grand
or i can get a cobra engine with the 6spd, driveshaft, fuel tank and lines, wiring, computer for about 5 grand more. id be building the engine up anyway, and id probably put a turbo on, but still.
iam gonna guess thats new engine, because if its not i can get a low mile cobra engine with an eaton on it of about 5grand.
2004 Crimson red GT saleen s/c, full bolt ons |
no, its not new
i cant find cobra engines for under 8 anywhere
Mach1 if u gonna build it up anyway why spend 5 grand more when that could go into a stroker kit twin turbos or other stuff? It'l be just as fast
http://www.cardomain.com/ride/3112249 |
do the sohc engines sound more aggressive with cams than the dohc?
i noticed that in some videos
where are yall finding all these engines cause ive been looking for some. where are yall finding a cobra engine with a eaton on it for 5g
2001 mustang gt 5 speed Full bolt ons with 4.10 gears. 1965 Mustang 302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter. In the process of restoring it... |
unstoppable @ speed of light
Keep an eye on e-bay for the 4v engines. There was one out of a Marauder a few weeks back for sale for under a grand. It was a teksid block, and that's a great deal...
The 2v vs. 4v idle will sound the same if the cams specs are the same. They do the same thing, open and close exhaust and intake valves. It can't make any more of an aggressive sound if it's the same sizes.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
13.9@101
It really comes down to whether you are going to do FI or not. If you aren't get the mach engine, because its aluminum. If you are planning on FI, go with the cobra engine because its already fully forged, with the iron block.
![]() 13.9@101 before some mods |
IBEATU
06 GT, 98 GT, & 93 Notch
For 5k less I would definately go with the Mach motor
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
the t45 wont mount up with the cobra engine right?
2006 Mustang GT
I would get the Cobra block, because it's cast iron, fully forged, and can handle a beating.
no if you get an 03/04 cobra motor you need the t-56 set up. I am pretty sure you can use the mach 1 motor wih the t-45 even though i think it is designed for the 3650. They are both five speeds so i dont think it would be an issue with the t-45 on the mach motor. If you plan on getting nitrous or doing forced induction i say go cobra motor. There is a set up on ebay right now for it.
You can probably get it for under 5k and it only has 20k on the motor and it is complete. It also comes with the blower so its already pushing good power out of the gate |
thanks
those t56 trannys are amazingly expensive though lol
im debating between the aluminum and iron blocks... the adavatnage the alluminuim being that it can be bored and repaired if one of my rods decided to redcorate...?
Considering selling my car to fund my race car: take a look and tell me what you think. http://www.moddedmustangs.com/forums...ml#post1041280 |
Is there a significant weight difference between the two engines?
#16 | |
13.9@101
There is a weight difference, aluminum is lighter but it is weaker, iron blocks will hold a lot more power than aluminum blocks... I'd go with the cobra engine... but definitely find a cheaper one
![]() 2004 GT Boosted by Vortech |
i cant seem to find a cheap one
and building an engine is like building a computer it costs way too much to do it yourself, you really dont save anything
#19 | |
It costs a hell of a lot less to build one yourself, wtf are you talking about?
well you can buy ones for like 5-6 grand
and i mean the block is like $300, the heads are $2000, the rotating assembly is another 2 grand, and all the other shit you need for it, it really doesnt end up to you saving any money
Threads Similar to: Mach 1 or cobra? (engine, that is)
| which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt | gtjason | New Members Introductions | 14 | February 19th, 2012 09:19 PM |
| 99/01 Cobra Or 03/04 Mach 1 | 00GT | 99-04 | 88 | April 16th, 2010 10:56 AM |
| Mach 1 engine block? | JAY'SRED02 | 99-04 | 12 | June 4th, 2007 02:23 PM |
| MACH 1 engine moddes ? | commpartspro | 99-04 | 9 | May 11th, 2007 05:09 PM |
| the mach one engine | allmustangs247 | 99-04 | 5 | April 10th, 2007 07:27 AM |
