Wierd Noises
Old September 29th, 2007, 08:50 PM   #1
MnrlGry01gt is on a distinguished road
Wierd Noises
OK on my way home from work tonight I was driving through the neighborhood and I started to hear some noises. It sounded like when you turn your wheel as far as possible and it makes that noise. I figured it was the power steering so I checked that and its only a little bit beneath low. Do you think its the power steering? Also I would keep getting these like bumps or kind of vibrations or something in the clucth, not when its pushed in but my foot is just on it.
Also, when I pulled into the garage and turned the wheel side to side it sounds like a spring getting stretched out and in from the passenger side. Any ideas? Thanks in advance!
Old September 29th, 2007, 10:42 PM   #2
hudini is on a distinguished road
Ford has put out a TSB for steering-squeak/creak noise while turning.. I have a 2003 Stang my TSB nbr is TSB 05-14-3 issued JULY 2005. My Stang had that noise you described and Ford fix it for me FREE. Hope this helps...
Old September 29th, 2007, 10:43 PM   #3
How do I find out?
Old September 29th, 2007, 10:50 PM   #4
Go to www.alldata.tsb.com and proceed to the TSB & Recall Titles. Let us know what happens,,,Good Luck
Old September 30th, 2007, 01:25 AM   #5
Ok well I fix the power steering but I still have this squeak coming from the front passenger side wheel when I turn. Do you think it just needs to be lubed up? If so where are the fittings for that side?
Threads Similar to: Wierd Noises
strange noises The Black Car V6 Mustangs 11 October 16th, 2007 08:34 PM
grinding noises? blue03mach1 94-95 4 July 3rd, 2007 07:57 PM
Weird Noises addict V6 Mustangs 17 February 8th, 2007 06:15 PM
noises from engine 92DRKGREENHB 5.0 Mustangs 8 December 4th, 2006 07:15 PM
Noises... Stan27 General Tech 20 June 22nd, 2006 04:06 AM
