RPM stuck at 2500 RPM?
I installed a "Professional Products" 75mm throttle body and upper intake plenum and when I shift gears or push in the clutch the car revs at 200-2500 rpm for like 20 seconds and then goes down to 1000 and idles.. I checked the throttle plate and all that good stuff and nothing seems to stick WTF? Think I need a tune? Ideas, suggestions?
48.47@ 12.58
it's sticking.
I believe Casper just had the same issue with this throttle body.
so is it just a cheap throttle body? I mean I guess it's not jacking up anything do I need to just deal with it or is there anything I can do to fix it?
The Hammer
Millenium Falcon
yeah.......except his was for a 5.0
i beleive the end result was Prof Prod is junk |
48.47@ 12.58
yes it's a cheap TB.
it's not really hurting anything but your mpg when it's stuck. you could try messing with the throttle plate I guess.
damn! See what happens when you cut corners?
lesson learned..
#7 | |
48.47@ 12.58
The Hammer
Millenium Falcon
if u explain ur name in it it'll kill two birds with 1 stone
accufab is the only way to go.
very true
#11 | |
2002 Gt
Not Slow
2002 Gt
Not Slow
i was so close to buying one of those professional piles of garbage, but then i manned up and went with the bbk plenum/tb combo. Man wut a smart idea
2001 Mustang SVT Cobra
BBK is made by Pro Products. Wake up people! Trick Flow, Dragon, C&L, all cut by the same factory. Just a word, I love my TB and it's a professional products TB 75mm. You can try and play with the spring or as it's stated in the box/instructions, you might need to re-adjust the butterfly nut. It can happen to accufab as well.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
im not a fan of anything bbk anymore. i keep getting holes in my headers. dont know why, but its gay, we patch them and a couple months later, it blows another hole in it.
Damn, why did you have to post that?!!!! Now I can confirm that my damn leak it's coming from a damn hole in one of the collector tubes! FK BBK! It looks like a little indent in one of the collector tubes, but now I have to go back and test. When I did sea foam last week, it was smoking more from the front left side than through the actual rear left pipe, that's how bad my leak is.
no good
#17 | |
2003 DSG Mustang Cobra
Thats why im glad i was able to get matrixpuba's Accufab combo for just $220
---1967 Mustang Hardtop V8 289 2bbl.--- ---2003 DSG Mustang Cobra Coupe---
Threads Similar to: RPM stuck at 2500 RPM?
| dodge 2500 | scxc15 | Drag | 7 | September 28th, 2007 07:44 PM |
| HELP! Severe detonation at 2500-3000 RPM! | SOHCman | V6 Mustangs | 36 | March 29th, 2007 08:11 PM |
| 2500$ | notsoslo5.0 | 5.0 Mustangs | 14 | February 21st, 2007 01:34 PM |
| 2500 Stall Be Fine | tag team | 5.0 Mustangs | 8 | October 24th, 2006 10:11 AM |
