13.9@101
UDP Install
I know you need an impact wrench to loosen up the alternator pulley. But do I need to use the impact wrench to loosen the crank pulley? I can't seem to fit my impact down there without hitting the fan. I've tried doing it by hand but it seems like its not having it. Any suggestions?
![]() 13.9@101 before some mods |
![]() iTrader: 1 reviews
i put a ratchet with a prybar on the end of the ratchet and it came off and then just use the harmonic balancer tool to pull it off.
1990 GT
yup what he said. i just used a pry bar and i think i had the car in 3rd gear.
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
13.9@101
Different gears make a difference? I had the car in 1st and it was still spinning a little.
i did it yesterday and i had to take the two bolts that hold the fan, move the coolant resivore, and raise the fan up some then the impact would get on there fine
#6 | |
13.9@101
I don't know if this helps...
http://www.mustangworld.com/ourpics/fcar/pull1.htm
Resident Bubblehead
put the tranny in first w/ e brake set. i used a 2 foot breaker bar on the crank pulley nut. if it still spins, use a floor jack and position it under the crank pulley. jack it up just enough to put some tension on the crank pulley to keep it from turning.
#9 | |
be very careful doing that, dont wanta break the snout off the crank
1986 Mustang GT t-top time piece! |
13.9@101
I got it down. For some reason it spun a little in 1st, but took sonicblue's advice and put it in 3rd and got it off.
Threads Similar to: UDP Install
| How to Install a Top | TurboLX | General Tech | 8 | March 1st, 2011 01:46 PM |
| *^$ HOW DO I INSTALL *^$ | mustang1072 | V6 Mustangs | 4 | September 27th, 2007 12:45 PM |
| CAI install | jabrennan | V6 Mustangs | 22 | March 10th, 2007 03:30 AM |
| sub and amp install | GreenFaleen | Audio/Video | 17 | January 4th, 2007 01:40 PM |
| HID install help | geekstang | 99-04 | 1 | August 26th, 2006 05:17 PM |
