Procharger Install
Old October 4th, 2007, 07:32 PM   #1
2001Mustang Saleen is on a distinguished road
Procharger Install
my budding is putting a procharger kit in his 99 cobra. I was wondering if the kit is do able doing it by ourselves or do we need to be professionally put in. How hard is it to put in and also what kind of tools do we need to put this kit in if the kit is do able by ourselves. I know it comes with good instructions and i do not know how hard it is to put the intercoler up and also the install of the injectors and the fuel pump.
Old October 4th, 2007, 07:50 PM   #2
Blivit is on a distinguished road
You can do it yourself if you are mechanically inclined. I installed mine by myself on my 01 gt. Prochargers "instructions" are garbage. It took me the better part of a day to get it finished, most of that time is spent trying to get all the tubing to line up due to the instructions not really telling you what goes where.
Here's a tip, remove the front bumper for the intercooler. I didn't the first time. It makes things much easier.
Old October 4th, 2007, 08:03 PM   #3
ya i plan on removing the bumper. How long did it take you to do it. Also i am not that good on installing stuff and my buddy is pretty good. It dosent seem that bad but i should be able to do it
Old October 4th, 2007, 09:09 PM   #4
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
Not a bad install as long as you have some basic mechanical skills. Hardest part is the fuel pump and injectors. Dont forget to run different plugs. NGK TR6 is what Id suggest running. Oh and yea the instructions are junk!
Bolt on list in Garage..
Old October 4th, 2007, 09:51 PM   #5
like what is the most difficult thing to do with the install. How hard is it to do the fuel pump and the injectors
Old October 4th, 2007, 10:31 PM   #6
The hardest part for me was getting everything lined up right and for some reason the power steering lines (you have to extend them becuase the cooler goes in front of the intercooler.) I had to take everything apart a few times to get it right.
The fuel pump is pretty easy as long as your tank is empty and the injectors are easy too.
Old October 4th, 2007, 10:46 PM   #7
ok thanks for the input
Old October 4th, 2007, 11:01 PM   #8
The Mean Green
MATT02GT's Avatar
Cut the p/s lines, then plug them with a bolt or something, then put the extension in. Drop the fuel tank to do the pump, pull the fuel rails to do the injectors and the plugs too. Pull the computer to do a chip (or get a handheld tuner) Worst part of the instructions are on how to mount the charger. It took me around 7-8hrs to do everything taking my time and alot of beer breaks. Just be sure to get a good tune...the tune is everything.
Old October 5th, 2007, 08:35 AM   #9
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
if you can change an alternator, you can install it.
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old October 5th, 2007, 10:58 AM   #10
ok thanks. Ya it does not look to bad but we will see how it will go. I will you keep you informed on the progress or if i have any questions
Old October 5th, 2007, 12:18 PM   #11
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Its an easy install...
Easier then a vortech IMHO...
Just refer to the plug heat index we have in the forums to see what plugs you need...
Its also based of what kind of boost the car will be running...
Check with the tuner for his preferred plugs...
Facebook
Google+
Old October 5th, 2007, 02:18 PM   #12
ok ya i will ask the guy
Old October 5th, 2007, 04:33 PM   #13
The Mean Green
MATT02GT's Avatar
NGK TR6 plugs with the Procharger
Old October 5th, 2007, 04:34 PM   #14
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Depends on boost levels bro...
Facebook
Google+
Old October 5th, 2007, 05:13 PM   #15
The Mean Green
MATT02GT's Avatar
True...Im assuming this is a stock motor
Old October 5th, 2007, 06:17 PM   #16
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
NGK
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
I run NGK BR7EF's but I am also running 12#'s of boost...
Facebook
Google+
Old October 5th, 2007, 09:56 PM   #17
ya i plan on running like 8 to 10 pounds of boost on a conservative tune. i should make some good power
Old October 6th, 2007, 03:27 AM   #18
1999 Mustang
Invictus is on a distinguished road
:wink
Threads Similar to: Procharger Install
Procharger Install 95% gsjohnson 99-04 40 December 4th, 2007 06:11 PM
Procharger Belt Install gsjohnson 99-04 6 November 1st, 2007 10:25 PM
Procharger & MAF??? mustang_marine 99-04 13 August 23rd, 2007 07:20 PM
Procharger install NEED HELP ASAP hawks05 99-04 2 March 15th, 2007 11:45 PM
05 Mustang GT After Procharger Install Vabeachmustang Pictures 21 November 16th, 2006 06:26 AM
