vacuum leak or brake booster vacuum leak - Forums at Modded Mustangs
post #1 of 12 Old December 29th, 2013, 07:35 PM Thread Starter
luv2shuv
luv2shuv's Avatar
Ive had a vaccuum leak for about a year already. I have replaced my intake manifold and gaskets with felpro gaskets and oem ford racing I/m.ive clamped all the hoses running off the cold air intake and the 1 f4om the pcv valve to valve cover. Car idles perfect and runs perfect. The vacuum leak sounds big real loud hissing so I cant understand how I would have no idle issues. Im starting to think it might be a brake booster vacuum leak. I do get a light hissing sound (seperate from initial leak hiss) when I step on the brake pedal. Any ideas?
04 gt. Mach 1 lip, grille delete, k&n cold air intake, 40 series flowmaster cat back, steeda tri ax short shifter
luv2shuv is offline
post #2 of 12 Old December 29th, 2013, 07:39 PM
Poo tee weet?
Buddha's Avatar
Our cars use hydoboost not vacuum boost.
Buddha is offline
post #3 of 12 Old December 29th, 2013, 07:45 PM Thread Starter
luv2shuv
luv2shuv's Avatar
Damn. Im gonna have to read up on how the hydro boost system works.
luv2shuv is offline
post #4 of 12 Old December 29th, 2013, 07:57 PM
Poo tee weet?
Buddha's Avatar
It takes hydraulic pressure from the power steering pump.
Buddha is offline
post #5 of 12 Old December 29th, 2013, 08:13 PM Thread Starter
luv2shuv
luv2shuv's Avatar
I see... so do you have any ideas about where I might want to check for a leak? I don't want to spend 150 $ bucks on a smoke test.
luv2shuv is offline
post #6 of 12 Old December 29th, 2013, 08:22 PM
black02's Avatar
iTrader: 7 reviews
Spray starter fluid around by the lines or back of the motor if there's a leak it will burn the starter fluid you'll hear it
Sent from AutoGuide.com App
black02 is offline
post #7 of 12 Old December 29th, 2013, 08:31 PM
Like stated above, starting fluid around the vacuum leak will affect idle.
2000 GT
jbodell11 is offline
post #8 of 12 Old December 29th, 2013, 08:47 PM
46L281GT's Avatar
Are you using the stock PCV valve or an aftermarket valve
1999 Mustang GT 5 Speed Vert
Procharger P1SC @ 7 psi
382/382 STD
Tuned by Chicken Hawk Motorsports
Supercharger Build Thread: http://www.moddedmustangs.com/forums...ld-thread.html
46L281GT is offline
post #9 of 12 Old December 29th, 2013, 09:23 PM Thread Starter
luv2shuv
luv2shuv's Avatar
I've done that. I had minor leaks on the hoses that run fron the pcv and the ones that run from the air intake so I clamped them but the leak is still their....
---------- Post added at 06:19 PM ---------- Previous post was at 06:19 PM ----------
Motorcraft... I bought it from the dealer.
---------- Post added at 06:23 PM ---------- Previous post was at 06:19 PM ----------
The thing that trips me out is how loud the leak sounds but it doesn't affect the cars idle but the sound goes away then i hit the throttle and the rpms fly up but as soon as its back at idle rpms.... bam the hissing is back... my buddys bmw has a leak that's half as loud and his beemer turns off when its cold at idle.
luv2shuv is offline
post #10 of 12 Old December 29th, 2013, 10:10 PM
46L281GT's Avatar
Oh okay then. The reason I asked is because I had bought a knock-off version and had a strange hissing/rattling sound and it was that crappy valve. I know they are supposed to rattle if you shake them, but this one was audible from within the cabin and definitely outside the vehicle. Just thought it might be the same issue that I had.
46L281GT is offline
post #11 of 12 Old December 29th, 2013, 11:20 PM Thread Starter
luv2shuv
luv2shuv's Avatar
A couple months ago I suspected of the pcv valve so I put the old one back on to see if it still hissed... and it did....
luv2shuv is offline
post #12 of 12 Old December 30th, 2013, 01:18 AM
07gtS197's Avatar
iTrader: 5 reviews
Get a vacuum guage and test the vacuum
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
07gtS197 is offline
Human Verification
