i posteed this in the drivetrain section, i need trans help
Old October 7th, 2007, 05:51 PM   #1
matfernan1 is on a distinguished road
Send a message via AIM to matfernan1
will the 03 cobra trans bolt up to my 01 gt, if so is it possible to just drop the trans, and use the bell housing i have now?
Old October 7th, 2007, 09:00 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
they do make a kit to swap to the t56. there are a few things different, bell housing, crossmember, shifter, driveshaft length, etc. this is a common swap, but you will need the parts to do it.
Old October 7th, 2007, 09:03 PM   #3
is it possible to take the bellhousing off with the motor still in the car?
Old October 7th, 2007, 09:13 PM   #4
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
yes, the first time you take the trans out it will be a bitch. after the first time it will be a little easier. the top 2 bell housing bolts are a little tough, but its not to bad. before i went to long tubes, me and a friend could have the trans on the ground in 45 minutes. thats working on the floor, not on a lift.
Old October 7th, 2007, 10:52 PM   #5
i have long tubes, is it still possible to get it out?
Old October 7th, 2007, 11:20 PM   #6
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
yeah, just a little harder. i am about to have to take my trans back out, i just installed my long tubes not to long ago.
Old October 7th, 2007, 11:44 PM   #7
well im sure you will have yours out before I have to swap mine, but let me know it goes, and thanks for the help
Old October 8th, 2007, 01:14 AM   #8
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
no problem. i have pulled my trans out 16 times and i am used to it. it is just another routine thing to me.
Threads Similar to: i posteed this in the drivetrain section, i need trans help
loud drivetrain noise... need4steed 2005 - 2010 5 October 31st, 2007 11:34 PM
engine/drivetrain swap into my 72 courier stook36 5.0 Mustangs 11 March 17th, 2007 03:05 AM
DriveTrain Specialists Ebay Store here for 7.5" gears 00SoSlow V6 Mustangs 17 August 8th, 2006 09:33 AM
cobra engine/drivetrain mods (write-ups) 99mustang232 96-98 0 March 16th, 2006 09:01 PM
