Installing Rear Gears, Quick Question
When I wanna replace my rear gears with 3:73s', can I do this easily? This means taking the axel spline out, right? Also, should I coat the ring gear with anything when I put it in? Im not doing this stuff NOW I just wanna know for future reference. Thanks
13.9@101
I wouldn't do it man. You can run into all kind of problems with the install and the after affects, if you aren't 100% sure and don't have a lot of knowledge of rear ends.
![]() 13.9@101 before some mods |
Really? You dont know how much a shop may charge to put them in for me do you?
48.47@ 12.58
around $250-$300.
2004 Mach One
Yea man unless you've done it a couple times I wouldn't recommend the install yourself. I watched mine get done, and wow i would have F'd something up. And Yea anywhere from $2-300 is good.
#6 | |
Assistant to the Manager
But You should be able find around $275
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng |
![]() iTrader: 1 reviews
yeah the shop i took my transmission to told me it'd be like $700
im like uh...id rather chance doing it myself.
#8 | |
Re: Installing Rear Gears, Quick Question
CAI, P&P 75mm Throttle Body and Intake Plenum, Pypes Cat Back Exhaust, FRPP 4:10 Gears. ![]() ![]() GOBAMA |
#9 | |
I Poop Entirely Way Too Much
Blown 03 GT
you need a dial indicator for starters, and then you need to do your homework and then i would say attempt it.
1986 Mustang GT t-top time piece! |
One Man Wolf Pack
If you try it and screw something up it will be alot more expensive having it fixed than it would be to just pay to have it installed. I say pay somebody.
![]() ΜΟΛΩΝ ΛΑΒΕ
justy take it to a shop to have them done ,,,its better to spend the 250.00 then to chance it :award
Blown 03 GT
my theory is even if you break it youll learn from your mistakes and it costs less than payin for classes to just fix ur mistakes and you learn more in the end. once you learn youll know forever and you can charge your buddies to do their to recover from your learnin losses
Threads Similar to: Installing Rear Gears, Quick Question
| About installing gears...of course 4.10's! | GT/CS | 2005 - 2010 | 6 | August 15th, 2007 11:33 PM |
| gears/rear end question | villatic | V6 Mustangs | 7 | July 30th, 2007 06:43 AM |
| rear end gears question | cdunc24 | 5.0 Mustangs | 16 | January 21st, 2007 05:37 PM |
| price on installing gears? | 02NEBstang | 99-04 | 4 | January 7th, 2007 01:45 PM |
| Installing new gears. | BiGD12590 | 99-04 | 19 | August 1st, 2006 06:59 AM |
