which one to have Romeo or Windsor
which one is the one everyone wants or would rather have and what is the difference?
much easier to find heads and such for romeo.....the windsors come with the 8 bolt crank. i think the windsor was only made for the 99-00 model years as far as mod motors are concerned.....?
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
windsor has the 8 bolt crank (most of them, some are out there with the 6 bolt), more bolts on the valve cover, cam gears are pressed on
that's all the differences i can think of off hand. they are the same engine with only minor differences. if you go with a forged crank in a romeo you can get the 8 bolt crank so that's not a big deal. |
Besides the 8 bolt on the windsor is cast.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
i see, thought one came with a forged crank already....so I have a windsor in my 03 gt?
no, 00 was last year with windsor
Proud American
01 was. and none have forged internals. Windsor heads will fit on romeo blocks and romeo heads on windsor blocks. Just basically different factorys, more valve cover bolts, and press on gears. Aftermarket cams require bolt on gears so there is no problem there at all.
pretty sure the heads for romeo / windsor are not interchangeable
Proud American
no they are!
12.73@111.36
I have a Windsor.
Question: I heard that Ford changed the way the cast rods and pistons in 2001. That was supposed to be why Procharger recommended 12 lbs boost, but only 8 lbs for 2001-2004. Then again, I heard that oo have Windsor motors and 01 have Romeo. Do you supppose the difference in recommended boost is actually the difference in Windsor and Romeo?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#11 | |
![]() 2004 GT Boosted by Vortech |
#12 | |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
#13 | |
MM's Mad Scientist
Slow Fella
#14 | |
MM's Mad Scientist
Slow Fella
The Windsor plant was forced place truck cranks in some of the motors during 00-01, because they couldn't keep up with production demands. The cranks are still cast- they just have 8 bolts. I have seen several 8 bolt cast cranks advertised as forged on Ebay. I am sure that unsuspecting/unknowledgable customers have gotten stuck with cast cranks after paying forged prices.
#15 | |
MM's Mad Scientist
Slow Fella
Assistant to the Manager
acmiller with the smack down! x4!
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng |
everything acmiller said is right. and another thing, theres not one thats really better, not one that holds or handles more power. they are both basically the same with the things that matt pointed out
#18 | |
MM's Mad Scientist
Slow Fella
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
showoff
#20 | |
MM's Mad Scientist
Slow Fella
Threads Similar to: which one to have Romeo or Windsor
| romeo or windsor | mystang0673 | 99-04 | 31 | November 25th, 2011 09:34 PM |
| romeo or windsor | energiesource | 99-04 | 1 | September 29th, 2007 01:59 PM |
| romeo vs windsor? | mystang0673 | 99-04 | 0 | March 5th, 2007 11:52 AM |
| romeo or windsor | TrueBlueGT01 | 99-04 | 5 | December 10th, 2006 01:26 PM |
| 11 bolts = romeo or windsor | niubodybuilder05 | 99-04 | 4 | December 6th, 2006 07:19 PM |
