Engine dies coming off hwy
Old October 12th, 2007, 09:49 PM   #1
frankyees is on a distinguished road
Was just getting off the highway tonight and the car dies on me. When I came to a stop I started the car right back up and went on my way. Any ideas what could of caused this? Its a 99 GT. Thanks Frank
Old October 12th, 2007, 09:53 PM   #2
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
How many miles are on it? What kinda maintaince has been done?
Bolt on list in Garage..
Old October 12th, 2007, 09:58 PM   #3
It has 95k miles on it. I just replaced the air filter, cleaned the IAC out. Just had an oil change. Dunno what would cause that.
Old October 12th, 2007, 10:05 PM   #4
The Mean Green
MATT02GT's Avatar
Has the fuel filter or plugs ever been changed?
Old October 12th, 2007, 10:07 PM   #5
That I do not know...guess that will be the next things I change out...is there anything else that I should look out for?
Old October 12th, 2007, 10:09 PM   #6
The Mean Green
MATT02GT's Avatar
Id start there, and run some good fuel injector cleaner through it, i reccomend BG 44k or Lucas injector cleaner.
Old October 12th, 2007, 10:20 PM   #7
Ok I will try that and see what happens over the next week. Thanks for your help.
Old October 12th, 2007, 10:56 PM   #8
finaly03vert's Avatar
03 gt vert
lights cant time it
finaly03vert is on a distinguished road
where was ur tac because they will shut off at red line if ur not carefull ? dont know just checking
NX EFI plate 250 jetcustom tune Eibach Pro-Kit Magnaflow cat back high flow cats, 3:55s, ported and polished heads, comp cams, forged pistons/ rods
Curently building up 03 mach block w stage 3 port job. look for twins and more n2o
Old October 12th, 2007, 11:26 PM   #9
Was not even in gear when it died.
Old October 12th, 2007, 11:46 PM   #10
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
ive heard of a few other cars"not just fords" doin that because the rpm dropped to fast an shut off before it idled back up,maybe thats what happen to you
Old October 13th, 2007, 12:44 AM   #11
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
mine does that if i push in the clutch and let it coast for a little bit. i had a problem with it doing it when i stopped, but it was the iac hose.
Old October 13th, 2007, 01:52 AM   #12
OcOnnor220 can only hope to improve
Mine comes close if I spend too much time riding the clutch in heavy traffic, letting go of the clutch in neutral and the rpms' drop too low. Also, A/C and heat will hurt your idle also.
Threads Similar to: Engine dies coming off hwy
Knocking Coming From Engine ajnightcryer3 V6 Mustangs 18 November 15th, 2007 10:50 AM
dies at 3k superman5.0 5.0 Mustangs 7 July 18th, 2007 05:26 PM
Car dies out Espo General Tech 1 August 22nd, 2006 01:21 PM
Oil coming out of front of engine OTreborO General Tech 3 May 30th, 2006 11:27 AM
Engine Dies While Driving Mystic Mama 96-98 7 May 6th, 2006 07:55 PM
