umm have a weird problem? idle problem?
Old October 13th, 2007, 01:04 AM   #1
blue03mach1 can only hope to improve
so it basically started today... my engine is idling at like 1200-2500 wtf? lets say i put it in 4th gear goign 35 it will drop around 1400 rpms as soon as i put it into neutral it rises up around 2 grand... its idling higher for some reason... vacuum hose? any help? oh btw... i turned off the car and waited and as i drove around it seemed fine and i got on it and slowed down put it in neutral and it started to idle at 2400rpms any ideas? its doing it either way, i take it easy or i get on it...
Old October 13th, 2007, 01:07 AM   #2
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
idile sensor maybe?
Old October 13th, 2007, 01:09 AM   #3
yeah... that might be it... my dad said that... easy cheap fix right?
Old October 13th, 2007, 01:11 AM   #4
2004 GT
slow....
pa.ulB is on a distinguished road
Send a message via AIM to pa.ulB
idle sensor?? i don't think its a vacuum hose, beacause that would just idle your car down until it dies, iam not sure. Check all your hoses attached to your intake plantium.
2004 Crimson red GT
saleen s/c, full bolt ons
Old October 13th, 2007, 01:11 AM   #5
tlr96's Avatar
tlr96 is on a distinguished road
TPS sensor?
view my garage for pics and modifications
listen to my exhaust video 1 video 2 video 3
Old October 13th, 2007, 02:47 AM   #6
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
check your throttle and idle sensors... get some cleaner and just wipe them down... see if that betters or worsens the problem...
its not a vacuum leak... i know what those are and you don't got one from the sounds of it... damn VW's
anyways best of luck on the fix
Old October 13th, 2007, 03:56 AM   #7
03MACH1STK is on a distinguished road
Take a look at the throttle body, to the left of it is a "IAC" or idle air control valve, it has a small wire harness plugged into it. This allows air to by pass the throttle body in the closed position so the engine can idle. Try removing it and cleaning any carbon and dirt. It may be sticking to cause the condition you are going to. May have to be replaced.
Old October 13th, 2007, 04:32 AM   #8
superbeef1000's Avatar
yup +1000
Old October 13th, 2007, 09:16 AM   #9
TyCouey2000GT is an unknown quantity at this point
Ya, good luck on the fix, I'd check all your lines running to the tb and such, especially the idle control screw and the iac.
Your Average GT
Old October 13th, 2007, 10:45 AM   #10
1000bucks are u serious?
Old October 13th, 2007, 10:46 AM   #11
btw thanks for all the info
Old October 13th, 2007, 10:52 AM   #12
DrHolliday is on a distinguished road
He was just strongly agreeing with you
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old October 13th, 2007, 10:58 AM   #13
wow i hope its not that then...i kinda want my headers to get installed monday
Old October 13th, 2007, 11:01 AM   #14
04gtvert's Avatar
04gtvert is on a distinguished road
If u have a good tuner you can run live data logging on start up or check the diagnostics.
Old October 13th, 2007, 11:02 AM   #15
it won't be $1000 bucks, i'm not sure how much the sensor is, but its way under 1,000
saying +1 or +1000 is just away of saying you agree with the previous poster. You should still be able to afford your headers.
Mustangless atm
Old October 13th, 2007, 11:06 AM   #16
ohh wow my bad...im still too tired im not use to waking up this early on a saturday
Old March 4th, 2008, 01:03 PM   #17
Hunt_chevs's Avatar
2002 Gt
Not Slow
my 99 had the same problem,.. not quite as drastic,.. turned out to be the tps sensor
Threads Similar to: umm have a weird problem? idle problem?
Weird tranmission problem or is it normal? MustanG_guy17 V6 Mustangs 4 October 15th, 2007 08:45 PM
Weird Acceleration Problem TheLocalGypsy 5.0 Mustangs 4 August 20th, 2007 01:27 PM
weird check engine problem... fastford3388 5.0 Mustangs 28 April 20th, 2007 10:28 PM
Weird Idle problem geolebon 99-04 17 February 17th, 2007 10:10 PM
need help with idle problem cooktheworld 5.0 Mustangs 2 August 21st, 2006 10:54 PM
