Need Brake line help
Old October 13th, 2007, 11:17 AM   #1
bdshort is on a distinguished road
I have a 99 mustang gt and bought a brake line kit from summit. I attached three of the lines but the right rear didn't fit. It had two hard lines coming into it. Is there a fitting or some other way I can attach the last braided line?
Old October 14th, 2007, 08:36 AM   #2
OcOnnor220 can only hope to improve
Do the fittings on the front match? I know that when I got my Cobra big brake upgrade kit I didnt use the SS brake lines cause I didnt know they were side-specific as far as fittings go and installed them on the wrong sides, gave up and used my stock lines since Im impatient. Another good question for Ford...why do they do things like this...And why do they use bolts that dont fit ANY ratchet head size on Earth...
Old October 16th, 2007, 12:07 PM   #3
All of the lines fit exept the right rear. The others fit directly and had no problems but this one has two hard lines and the braided cable from summit only has one input.
Old October 17th, 2007, 02:56 AM   #4
Can you post a picture or a link to one like the kit you have? If not, try looking at YearOne or LateModelRestoration for a replacement hose with the right fitting, you should be able to tell by the picture. I wish I could be of more help but a picture would be good.
Threads Similar to: Need Brake line help
4 cyl swap...rear brake line Way_Fast_Whitey 5.0 Mustangs 14 September 6th, 2007 11:04 PM
Brake booster line? mustangmanic 99-04 16 September 3rd, 2007 02:34 AM
Brake Upgrades/ SN95 Spindles and Cobra Big Brake Kits OcOnnor220 Modular Mustangs 2 July 8th, 2007 01:36 AM
Cobra brake or bullit brake upgrade 97gtstang 96-98 5 May 14th, 2007 03:15 AM
Brake line routing from proportioning valve 83 5.0 94-95 0 March 23rd, 2007 10:46 PM
