![]() iTrader: 1 reviews
IRS swap?
so seeing as how most cobra owners go to a live axle, has anyone put an irs on their gt? are there kits available?
thanks
It should interchange, but I'm not sure of a kit. I don't see why you'd want to unless you are doing autocross or road racing though.
Well live axles are only really good for drag racing, and i wont be doing much of that.
¡ʇsnq ɹo uʍop ǝpısdn
i have seen it done to a V6 before... it is a time consuming swap... just need to be patient but it is very possible... gotta change your cat back too...
lemme see if i can find some linkies to help you out
thanks
http://www.2kgt.com/item.php?itemid=164
http://www.3.8mustang.com/forum/show...dependent+swap just ideas edit: your bolts up a ton more easier then this but some good pics http://www.mouthbreather.net/IRSSWAP.HTML
#7 | |
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
if u wanted to keep the irs but beef it up what should you get? or would it be smarter to just swap it?
you might want to see if there are trans axle rebuild kits... to see if you can beef up the ... i don't know what they are called but on front wheel drives they are the CV joints...
see if you can rebuild those to be strong as hell... thats the only things i can think of
The half shafts are what break the most .. and are expensive to fix .. you're really better off building a solid rear end if you're planning on dragging your cobra often
Car For Sale on Autotrader.com 04 Silver GT 32K Miles
Parts 4 Sale: 18" Wheels SSR GT3 replicas w/ tires Steeda Tri-Ax 10lb N20 Bottle w. gauge (2) Kirkey Racing Seats w/ RCI 5 Pt. belts Steeda & Momo shift knobs SB GT Spoiler |
Wheelhop is the death of an IRS. Stop the Hop stop the breaking. Get a Billetflow Diff Cover Brace and change out the rubber bushings, MM has a great set also so does Steeda.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
a friend of mine is contemplating on doing the same swap in his mach right now. it will interchange but you will have to change a couple things. exh., abs wires, brake lines, and caliper mounting are the ones i can think of right off the top of my head.
Threads Similar to: IRS swap?
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 05:33 PM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 01:57 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 07:48 PM |
| 3.8 swap to 5.0 | goldhorse | V6 Mustangs | 1 | August 10th, 2007 01:57 AM |
| 351 Swap | Cskit1500 | 5.0 Mustangs | 6 | November 16th, 2006 08:40 PM |
