Short block or 4v
Old October 18th, 2007, 07:02 PM   #1
Badasstang281's Avatar
Badasstang281 is on a distinguished road
Send a message via MSN to Badasstang281
Short block or 4v
Planning on doing a short block in a few mounts. Or I can get a 01 cobra with everything I need to put in my 02 GT. What should I do and how much HP can a 01 cobra motor handle with stock internals???
BBK cai P&P 75mmtb P&P plenum BASSANI exhaust MAC x-pipe NO CAT"S ACCEL direct fire coils NGK iridium spark plugs lX7 Eibach pro-kit springs
Old October 18th, 2007, 07:30 PM   #2
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
stock internals would be the same range as we have up to 450 rwhp maximum
2004 GT Boosted by Vortech
Old October 18th, 2007, 08:25 PM   #3
2001Mustang Saleen is on a distinguished road
no dude i have a 2001 cobra and i run it at 490 and 10 pounds of boost and i have been fine for awhile. The cobra motor can hold alot more than the gt motors
Old October 18th, 2007, 08:30 PM   #4
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
you would be much better off getting a forged shortblock for your 2v. it will have a lot more potential unless you go with a termie engine.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old October 18th, 2007, 09:59 PM   #5
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
Why not just forge your stock block? It'll be cheaper than buying a forged shortblock, unless ur looking for a 302 shortblock, then by all means buy the 302 lol.
But if ur lookin to buy a 281 shortblock, you might wanna consider forging you stock block instead, much cheaper and with the stock crank, u can still handle upwards of 650rwhp.
03-04 termi internals on a 2v gt works very well... and you could handle over 800 with that.
Old October 18th, 2007, 10:14 PM   #6
Ya I just want a respectable street car so I think that 450whp to 500whp will put me there. So are stock crank will handle 650whp or so that’s good to know. Maybe I will just get rods and pistons.
Old October 18th, 2007, 11:19 PM   #7
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
The rods and pistons are still not forged. I seen gt's run at 500+ for years a on the stock SB but most blow. I bit of bad gas, weak fp, hit rev limiter a little hard and boom.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old October 18th, 2007, 11:24 PM   #8
jivepepper's Avatar
Its not much cheaper to build than it is to by a shortblock after machining and balancing.
Termi shortblock will increase the compression ratio when used with 2v heads. That's because the 2v heads have a small combustion chamber. If you don't care about that then they are great. But not as boost friendly as with the 4v heads.
Old October 19th, 2007, 04:22 PM   #9
you can put 2v pi heads on a termi? thats odd. lol
So does that mean, i could put termi heads on my gt?
Old October 19th, 2007, 04:28 PM   #10
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
yeah you can, but you will have to get some holes drilled.
Old October 19th, 2007, 09:57 PM   #11
is that practical at all, what kind of HP gain would i be looking at with 4v heads?
Would it just be cheaper to port and polish or do some patriot heads?
Old October 19th, 2007, 09:59 PM   #12
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
heh..
even with a P/P you will never flow what a 4v head does stock.
Old October 19th, 2007, 10:15 PM   #13
so would a 4v head swap be practical? what kind of hp and ca$h am i looking at? cuz i would most do that if it wasnt too expensive...
what all would be involved?
Old October 19th, 2007, 10:34 PM   #14
zkid01 is on a distinguished road
As far as being practical, i think that is more of a personal opinion. A good built block w/ some upgraded p/p heads and boost will do just fine for anyone who wants a respectible street car. I hear the 4v swap is more trouble than its worth. JMO though.
Work Hard....Play Harder.
Old October 20th, 2007, 12:37 AM   #15
Yeah thats what i was thinking.
Since it would be a 4.6L 4v, would it pretty much sound like a cobra, you know, that smooth high pitch scream?
Also, by just doing that, would u be able to put a stock eaton termi blower on? or would an upgraded intake be needed also?
Old October 20th, 2007, 03:11 AM   #16
jivepepper's Avatar
For the teskid block you do, but not for thr iron 03 cobra block. It s just one water passage for the teskid I think.
Old October 20th, 2007, 03:22 AM   #17
jivepepper's Avatar
It would be about the same a as a low compression 4v motor. The basic geometry is the same for all modular blocks. Its the heads, intakes, cranks, and pistons that make the differences,
The ported heads would be less expensive. Because you need 4v heads with cams lifters etc, intake, exhaust manifolds, fuel rails, 4v timing chain cover. new h-pipe, it goes on lol.
Old October 20th, 2007, 05:16 AM   #18
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
With enough money you can do anything but forged rods and pistons and a supercharger will get you there. FI overcomes some of the shortfalls of the 2v motor. I've been told that with FI the stock 2v heads are good to around 600 whp.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Threads Similar to: Short block or 4v
new short block bobnasty 99-04 0 October 26th, 2007 07:47 AM
short block differs from a long block how? mustangfox9091 5.0 Mustangs 35 September 26th, 2007 10:57 PM
short block vs long block? caintcatchmyGT 96-98 3 July 22nd, 2007 09:47 PM
MMR Short Block vs DSS Short Block superbeef1000 99-04 6 September 20th, 2006 04:49 AM
5.0 short block AtxStang 99-04 5 August 20th, 2006 07:26 PM
