idling problem
Old October 19th, 2007, 04:45 PM   #1
02MiNeRaLgRaYGT is on a distinguished road
idling problem
today i was driving and when i got to a light a couple times the rpms dropped to about 500 and almost stalled. its been idling a little rough at times lately. any ideas on what could be the problem? ive had my fuel injectors cleaned and my air filter changed not too long ago and i run premium gas with a hypertech tuner. thanks for any help.
Old October 19th, 2007, 05:26 PM   #2
HessiaN257's Avatar
13.9@101
HessiaN257 is on a distinguished road
Sometimes that happens with the air on or the windshield defogger. Run some sea-foam or something through if you haven't yet, or in a while.
13.9@101 before some mods
Old October 19th, 2007, 05:35 PM   #3
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
you might want to clean your IAC valve. it could be sticking..
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old October 19th, 2007, 05:51 PM   #4
2kGT's Avatar
2kGT has a little shameless behaviour in the past
+1 on IAC. Take a wrench or something and tap on it (dont beat it). if the problem clears up, you need to either clean or replace the IAC.
Accufab 75mm tb & plenum
MRT h-pipe
Flowmaster catback
FRPP king cobra clutch
FRPP aluminum driveshaft
FRPP 4.10 gear
TA Perfromance girdle
Steeda tri-ax shifter
Moser 31 spline axles
FRPP C Springs
Old October 19th, 2007, 06:21 PM   #5
i had on the air and the lights if that would make a difference, it does seem to do it more often with the air on. whats sea-foam? and what do u mean run it through?
Old October 19th, 2007, 06:21 PM   #6
dmachine22's Avatar
1998 Z28
dmachine22 is on a distinguished road
Or make sure your TB screw isnt in to far, mine was idling real rough until I adjusted my screw and now it idles around 600-700 just fine!
* ONLY if you have a aftermarket TB and plenum I have 75 *
Unknown
Old October 19th, 2007, 06:29 PM   #7
HessiaN257's Avatar
13.9@101
Sea-Foam is a carbon cleaner, run it through a vacuum hose, oil, or gas tank. Let it sit for 5 minutes, then start it up. You will notice all white smoke coming from the pipes. Its a great cleaner.
Threads Similar to: idling problem
Idling problem dothedew1654 94-95 9 November 3rd, 2007 05:01 PM
Idling/Ding Problem fuanfwab 5.0 Mustangs 2 August 2nd, 2007 03:22 PM
Idling problem 302pusher 5.0 Mustangs 4 August 1st, 2007 04:57 PM
idling afmustanglover General Tech 7 April 4th, 2007 10:39 AM
My 86 idling 5literJeff Videos 1 January 18th, 2007 05:26 PM
