cams with stock pistons
Old October 22nd, 2007, 07:51 PM   #1
Badasstang281's Avatar
Badasstang281 is on a distinguished road
Send a message via MSN to Badasstang281
I have herd that I can run comp stage 2 cams with my stock pistons right? And can I run the VT Stage 2 N/A Cams as will or just the comp stage 2
BBK cai P&P 75mmtb P&P plenum BASSANI exhaust MAC x-pipe NO CAT"S ACCEL direct fire coils NGK iridium spark plugs lX7 Eibach pro-kit springs
Old October 22nd, 2007, 09:11 PM   #2
WNTS 2RN's Avatar
2011 Mustang GT
WNTS 2RN has a spectacular aura aboutWNTS 2RN has a spectacular aura about
I have the Comp XE278AH cam with stock pistons with no issues and they have .550 lift. So unless you put them in wrong they'll work.
1.3 gallons of American performance!!
K&N drop in (I know, I'm cheap)
Flowmaster American Thunder exhaust
H&R Super Sport springs
Bremmer BR01 19x8, 19x9.5 wheels
Bottomless bottle of soap!
Old October 22nd, 2007, 09:13 PM   #3
what is you’re duration
Old October 22nd, 2007, 09:20 PM   #4
2000 Mustang Gt
13.56 @ 106
2000stangGT is on a distinguished road
comp stage 2 (XE270AH) wont work unless you degree them correctly. if you don't degree them you will have ptv issues.
vt stage 2 will work, but you need new springs and of course a tune
btw stage 2 isnt worth it unless you have headwork
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams
Manley Valves/Springs - Centerforce Dual Friction
BBK LT's - BBK o/r H - Bassani catback
FRPP 4.10s - XCAL2 - BBK UDP's
306rwhp/333rwtq
Old October 22nd, 2007, 09:22 PM   #5
WNTS 2RN's Avatar
2011 Mustang GT
242 intake/246 exhaust. If you get these you'll need new springs. I used Comp Springs, Summit part number CCA-26113-16. The car has a real nice loap. The drivabilty is fine and the power is great. I couldn't imagine if I had new heads!
Old October 22nd, 2007, 09:27 PM   #6
Bagged97 where did you get your cams?
Old October 22nd, 2007, 09:28 PM   #7
WNTS 2RN's Avatar
2011 Mustang GT
Summit
Old October 22nd, 2007, 09:37 PM   #8
You did not have to miss with the degrees you just put them in? from what I can see is they are stage 3
Old October 22nd, 2007, 09:44 PM   #9
WNTS 2RN's Avatar
2011 Mustang GT
Twist2Go installed them for me but as far as the directions go you degree them to stock. When I called him for opinion he was quick to reccomend them seeing how I was going to get the 268 which is a mild cam. If you have any doubt on the degree you can install them to stock then turn the motor over at the crank. If it doesn't make a full rotation then add or remove a couple degrees at a time till it does. That said unless it's way off it will not cause PTV issues.
Old October 22nd, 2007, 11:59 PM   #10
2000 Mustang Gt
13.56 @ 106
wow, wen i called comp they didn't recommend the 270 or 278 with stock pistons.
i called Scott at vt and he stated the same thing, he also said nothing above stage 1 without head work.
306rwhp/333rwtq
Old October 23rd, 2007, 11:48 AM   #11
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
shouldn't be a problem. just GET A TUNE if your going with stage 2's and she'll run like a champ!
Old October 23rd, 2007, 12:05 PM   #12
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
just degree them right and you'll be ok. Go stage 2 and be ready for some head work down the line...
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old October 23rd, 2007, 05:45 PM   #13
energiesource's Avatar
energiesource is on a distinguished road
how do the numbers work, i know they're duration and lift and all that, but is a 262 more agressive than...268 or is the higher the number the more agressive sounding?
Old October 23rd, 2007, 08:35 PM   #14
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
the higher duration is more aggresive and generally dictates the power rpm band. as far as the aggresive exhaust note it is the lsa--the lower the number the rougher the idle(it also effects power rpm band)
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old October 23rd, 2007, 08:39 PM   #15
I think that with a higher the duration the more aggressive it is. And the duration is how long the valve will stay open. And the lift is how much the valve opens.
Will I just decided to go with the Vt stage 2 N/A cams
Old October 23rd, 2007, 08:42 PM   #16
if you buy boost cams will they harm anything? or just not perform as good as they would with FI
Old October 23rd, 2007, 08:48 PM   #17
limited's Avatar
if you plan on fi in future,then get blower cams. vt stage 2 blower cams also improve hp n/a. A very good choice imho
Old October 23rd, 2007, 10:35 PM   #18
WildWill's Avatar
1995 Mustang GT
good call. that's a great cam. and you're correct on the "numbers" too. A 262 cam is less aggressive than a 268 cam, a 278 cam etc... the higher the number, the bigger the lope and the rougher the idle.
the only difference in boost cams and na cams is their timing. running boost cams on an na motor won't hurt or help you any more than running na cams... but they will def help you once you smack a blower on that thing!
Old November 25th, 2007, 09:07 PM   #19
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
i was looking at cams and springs and was thumbing through some books, what if you ran the comp 274 cams for an NPI motor in a PI motor, they have .500 lift so you might be able to get away without springs, this is a stage 3 cam for the NPI motors. just curious as to the effects of that in the PI motors with stock heads
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Threads Similar to: cams with stock pistons
Pistons Micro Ford 2005 - 2010 2 October 11th, 2007 10:08 PM
cams on stock 302 notsoslow50 5.0 Mustangs 12 September 18th, 2007 06:49 PM
Pistons 95wip 94-95 3 April 14th, 2007 06:35 PM
What is the Biggest cam with 202 valves on stock pistons Kevin b 5.0 Mustangs 7 January 3rd, 2007 12:21 AM
V6 Pistons 1994redmustang General Tech 4 December 1st, 2006 08:12 PM
