question about emergency brake light
Old October 24th, 2007, 12:12 PM   #1
Paulnhbtx's Avatar
Paulnhbtx is on a distinguished road
when I'm driving the emergency brake light comes on as if its on.. it does not seem to effect the performance I'm just curious as to why it comes on like that..
Old October 24th, 2007, 12:32 PM   #2
HessiaN257's Avatar
13.9@101
HessiaN257 is on a distinguished road
Check you brake fluid.
13.9@101 before some mods
Old October 24th, 2007, 12:38 PM   #3
putermech's Avatar
1999 GT Black Coupe
putermech is on a distinguished road
My switched worked it way lose and had the light come on like you discribed until I did this.
The switch is a small plastic peice located on the passenger side of the e-brake which is held in place by one screw. Remove the middle arm rest to expose the brake and you will see it clearly. If it's lose, remove it and apply loctite and place it back in place. Also check the wire for damage.
5 Speed w/ Trac-control
Threads Similar to: question about emergency brake light
Emergency brake cable help Newtgadget 5.0 Mustangs 1 October 16th, 2007 08:57 PM
Third brake light ByPopularDemand V6 Mustangs 39 August 3rd, 2007 01:40 PM
emergency brake problems usmcsawgunner 5.0 Mustangs 4 June 15th, 2007 01:26 AM
Emergency!!!!..............................Brake flames_blue V6 Mustangs 15 April 12th, 2007 08:28 PM
Annoying emergency brake light HedCR 99-04 10 February 9th, 2007 07:04 PM
