flywheel
Old October 25th, 2007, 02:19 PM   #1
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
flywheel
i have an 01 gt....and its time to change the clutch and flywheel..ive heard about the bullshit about some 01s having 6 bolt and some having 8 bolt flywheels...i know i have a t 45 because i have an early 01...does the t45 have the 6 or 8 bolt flywheel?
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Old October 25th, 2007, 04:52 PM   #2
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
if you have a Windsor engine, you have an 8 bolt crank. if your car was built in early '01, it's probably a Windsor with an 8 bolt crank.
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old October 25th, 2007, 07:17 PM   #3
2kGT's Avatar
2kGT has a little shameless behaviour in the past
look at the driver side valve cover - should be a white sticker on there. Look real close. There will be a bunch of numbers all over it, but in small print it will say "Ford Windsor" if youve got a windsor motor.
Accufab 75mm tb & plenum
MRT h-pipe
Flowmaster catback
FRPP king cobra clutch
FRPP aluminum driveshaft
FRPP 4.10 gear
TA Perfromance girdle
Steeda tri-ax shifter
Moser 31 spline axles
FRPP C Springs
Old October 25th, 2007, 07:21 PM   #4
Resident Bubblehead
00vabchgt's Avatar
count the bolts holding down the valve cover. if there's 13, you have a Windsor. if there are 11, you have a Romeo. a Romeo will have a 6 bolt crank. don't know why i didn't say that in my previous post. i gotta stop smoking crack...
Military Crew
MM1 (SS)
US Navy Veteran
Old October 25th, 2007, 09:19 PM   #5
neckbonekat's Avatar
2005 Cadillac STS V8
http://www.americanmuscle.com/spec-a...nsmission.html
This SPEC Billet Aluminum flywheel has an 8 bolt main that is found in the 1999-mid 01 Mustang GT's with production date ending on 01/01, 1996-2004 Mustang Cobra's and 2003-2004 Mach 1's. Please check with your Ford dealer to determine if you have a 6 bolt or an 8 bolt main.
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old October 25th, 2007, 11:46 PM   #6
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
crack kills dude
Threads Similar to: flywheel
Flywheel Help the real shocker 99-04 11 November 12th, 2007 03:48 PM
I need a new flywheel Cfears2000 Pictures 2 September 29th, 2007 06:27 AM
Flywheel bbrewer03 96-98 6 August 18th, 2007 10:47 PM
Flywheel? gregkelley 5.0 Mustangs 24 March 17th, 2007 06:19 PM
flywheel mustang1072 V6 Mustangs 7 February 19th, 2007 12:05 AM
