what do i need for cams?
Plan on doing vt stage 2 N/A cams do I need to do new retainers and or Bolt-On Cam Gear Kit??? I know I need new Spring.
BBK cai P&P 75mmtb P&P plenum BASSANI exhaust MAC x-pipe NO CAT"S ACCEL direct fire coils NGK iridium spark plugs lX7 Eibach pro-kit springs |
1995 Mustang GT
new springs def for a stage 2 kit. i would get the cam gear kit too. make sure you have the right tools to adjust your timing (i've never done a swap, so i couldn't tell you exactly what, but somebody will chime in im sure).
99 limited edition vert
get the matching retainers,I am putting in a set of vt stage 3 blowers as we speak and I am using the crower high load with tit. retainers. the retainers are machined so the spring sits higher on valve(installed height) allowing for use of higher lift cams.if your doing the springs with heads still on the car then you will need the spring compressor tool also
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
2000 Mustang Gt
13.56 @ 106
alls you really need is new springs, cam gear set if you 99-00 and then a tune
retainers would be added measure but they're not neccessary
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams Manley Valves/Springs - Centerforce Dual Friction BBK LT's - BBK o/r H - Bassani catback FRPP 4.10s - XCAL2 - BBK UDP's 306rwhp/333rwtq |
Its "recommended" that you degree the cams. I have the Stage 2's and I didnt . I dont have any problems.
Stage 2's take serious tuning to get em right. They make their power up high,you will only really benefit from them if you get like 4.10s to get the rpm's up quicker. But they sound like war in my car. Timing--------CLICK
Fryrice has left the building. |
2000 Mustang Gt
13.56 @ 106
im geting the same cams over the winter, with P&P stock heads and new headers!
cant wait
You definitely need gears for the Stage 2's .
2000 Mustang Gt
13.56 @ 106
i have 4.10s lol(in my sig)
ive done my research lol
^ sweet.
Not use to such a high class sig.
Threads Similar to: what do i need for cams?
| Best Cams | hubba076 | 99-04 | 11 | May 23rd, 2007 09:13 AM |
| CAMS | leebunnyz | 2005 - 2010 | 1 | May 19th, 2007 04:14 PM |
| cams for a v6? | Torry Jobe | V6 Mustangs | 22 | March 15th, 2007 03:42 AM |
| PI cams | 97_stang_gt | 96-98 | 4 | February 23rd, 2007 08:54 PM |
| cams | landbstangcrzy | 96-98 | 1 | December 4th, 2006 07:15 PM |
