Discussing 4.6L Stroker kit in the 99-04 Forum. Who makes the best one and what are you looking at for gains?... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
4.6L Stroker kit
2000 Mustang GT, Custom grind cams, Steeda Triax shifter, Underdrive pulleys, SLP LM2, MAC L/T and O/R H-pipe. Transmission fix, new clutch White Stang Crew Member #1
Gains N/a will be marginal if any, forced induction will see up to 25+ rwhp and 30+ rwtq. There are pleny of good companies, you have to choose what you like.
thats it? what the fuck
how can vw cram 400 fucking horsepower into some 2.3l tiny crap engine and we cant even get that out of a 4.6l v8
2 valve head are not efficient, there is not enough in a 2 valve head to add cubes without adding a ton of bore. The biggest issue is the intake valve is being shrouded.
okay so i'll build a 1 liter engine but put dohc's in it and i'll have a million horsepower, awesome. makes sense.
#6 | |
You can get to 300 ci two ways, larger bore or longer stroke. A longer stroke is supposed to give more low end torque, but not much on the top end. Think truck engine. I have talked to a tuner who told me that some people are disapointed with their stroker motors, but it hard to talk them out of it when the stroker forged kit only costs a couple of hundred more then the standard forged kit.
All displacement is not equal.
latest tune: 370 rwhp/377 rwtq Garage: http://www.moddedmustangs.com/forums...-member-11329/ Previously Owned: 1966 Coronet 500, 426 ci est. 290-300 rwhp 1969 Camaro RS/SS, 350 ci est. 210-220 rwhp Today is the real muscle car era. |
Dude, build it and boost it. You can see plenty of power outta the 2v's with boost, especially if you've got some forged internals.
Its not how fast you drive, but how you drive fast. 2002 Mustang GT... Just The Usual Bolt-Ons 1997 GT.... For Sale! ![]() http://www.myspace.com/matt02gt |
I have an eagle stroker kit with all forged and balanced internals. The engine builders I talked to all used the eagle kit. I set mine up with low compression for boost. My internals are rated to 1500 hp I believe. The bore was increased by .030. I am at 278 rwhp and 300 tq. I need a good tune. I also upgraded my heads to patriot stage 3. My intake is a typhoon which has also been ported and polished. I really need a turbo or supercharger. My gears are 3.55's. I can tell you that I have no traction in first (no drag radials yet); and the car does not suffer from lack of top end. I have put the needle past 150 on the speedo and was just above 5000 rpms when I glanced down. I did this on an empty highway a couple days ago. I can feel a substantial difference down low. The car also has a deeper rumble to it. The stroker kit was about $3500 not including machine work and balancing, or installation. Hope this helps if you have any other questions feel free to ask.
¡ʇsnq ɹo uʍop ǝpısdn
hey don't worry that 2.3 is mos def a built 16v with a turbo on it... volkswagens are crazy... and you know what gets even more sick... if its and older one that thing is light as hell... and can be pushin a power to weight of a corvette or Ferrari depending on model ...
if you bore stroke and tune it properly and add other things such as cams forged pieces and also tune it you will see a noticeable gain |
Threads Similar to: 4.6L Stroker kit
| Stroker Kit 101 | scxc15 | V6 Mustangs | 5 | November 4th, 2007 12:46 PM |
| To Stroker or Not to Stroker? That is the Question! | 87StangLX | Power Adders | 13 | October 20th, 2007 10:46 AM |
| 347 stroker | mustang_s | 96-98 | 2 | August 7th, 2007 10:57 AM |
| 347 stroker | 2007calispecial | 5.0 Mustangs | 8 | July 31st, 2007 07:55 PM |
| 331 stroker | ballzout | 5.0 Mustangs | 8 | July 20th, 2007 04:59 PM |
