o1 gt mods whats next?
hi, im new here , i have an 01 gt,mt . i have already put in a dynomax cat back system,70 mm upper plenum and tb,cold air intake, i recently got a 80 mm mass air and was told i need to calibrate for this , do the custom tuners like hypertech and sct do this and do i need to go with bigger injectors as well. also i was considering headers , is it worth the time, oh i also put in the bbk underdrive kit. thanks
Smelly Fists, Socking Cocks
Millenium Falcon
the sct will do u just fine....hypertech is crap.
u don't need bigger injectors.... |
welcome to the forums.
your Gt already has an 85mm mass air. you don't need bigger injectors for a while yet. Yes Tuners can Calibrate that though. headers are a half decent mod but I would look into long tube's. I would suggest gears for your next mod.
hey thanks , what about the headers, and how much differance can i expect with the mass air and the tuner?
i was told the stock gts in 01 had 55 mm mass air.
you would be down grading if you put the 80mm mas air on.
you already have an 85mm. the headers will pick up a good 10HP. and the tune would depend on what exact mods you have. it should be in the range of 20hp though
#7 | |
#8 | |
88 LX automatic-non stroked 302 with iron heads 01 GT manual-h-pipe bullets dumped-125shot 97 GT automatic-SOLD |
Gears should be next, 4.10 if you are not going to supercharge or turbo and 3.73 if you ever do any of the for mentioned.
Something I did on my 01 GT was cams, I did stage one cause I wanted low end power. Also the stage one cams allowed power to stay constant once it hit peak all the way to redline unlike stock cams which started to fade off. You have to remember, power is not everything. If you can not put the power to the ground then its not worth a damn. Suspension is worth it. Since you have a 5speed then consider getting a short shifter, you'll hear a ton of opinions on whats best but by far more people like MGW. |
hi, another ?. i have an 01 gt made in aug.01 has a 5 speed tranny, which tranny is that that i have , i am looking at the short throw shifters, thanks
t-3650
Actually the 99-04 Mustangs have an 80 mm MAF stock. You can buy an upgraded 80mm MAF for the 99-01 Mustangs and you can get an 85 mm MAF for the 02-04 Mustangs
04 GT Auto K&N Typhoon Intake MAC Long Tube Headers MAC Prochamber Flowmaster Racing Series Mufflers 3.73 Gears TransGo Shift Kit Ground Wire Kit Helix TB Spacer [img]http://i149.photobucket.com/albums/s54/krispykremediet/IMG_0215.jpg[/img] |
hi, thanks ,i got an upgraded roush 80 mm mass air im going to try, also what are the stock rear gears in my 01 gt?
does anyone on here have the xcalibrator for an 01 gt they want to sell, or im looking at one on ebay, but it says needs to be reprogrammed, can this be done at home or do you need to take it somewhere?
your stock gears are 3.55s where as automatics are 3.27s
#16 | |
Resident Bubblehead
my bad I was thinkin of something else stock gears are 3.27s
Resident Bubblehead
terminators came with 3.55's and i think the Mach's did too, but i'm not sure.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
+1 3.27 for you, 80mm stock maf, stock injectors are fine to around 330rwhp, headers always a good thing, gears a good thing too. sct, diablo, and sniper will be the best tuners out ther. i use the diablo and have also used the superchips and hypertech, first hand experience i say they are junk!
I say go with a gear/ tuner kit. I got the Diablo tuner and 4.10 setup from americanmuscle. com. It was amazing what a difference gears will make and your gonna need the tuner anyway.
Threads Similar to: o1 gt mods whats next?
| Whats next on the list of mods | 06GTMustang89 | The Clubhouse | 10 | October 18th, 2007 09:33 PM |
| Whats with it | Drick | The Clubhouse | 23 | October 13th, 2007 02:36 AM |
| whats up | petrol_head | New Members Introductions | 11 | June 6th, 2007 03:57 AM |
| whats up... | joejoe8455 | Modular Mustangs | 1 | May 15th, 2007 11:23 AM |
| whats up! | cooktheworld | The Clubhouse | 2 | November 10th, 2006 07:59 AM |
