MM's Orangest
2004 Mach 1 Mustang
Shifter Problem
This only applies to driving hard. When I drive easy (99%) of my driving I have no problems. But when I decide to get on it I'm having a problem. I recently installed a new shifter so I'm thinking it is that, but here's the problem. I go through first, shift to second, get to 5500-6200 rpms, and here's the tricky part. Usually that's around 60mph roughly. Ok by this time if I usually have to start worrying about slowing down, but even if I get to third, third isn't my problem. It's fourth. When I go to throw the car into fourth the shifter pops it back to neutral. I'll have to make sure, but I think the clutch is still in when this happens. If not it is right after I let off. So my car goes right back to neutral and I rev hard when I get back on the gas if I don't watch it. But when I let the car coast for a second or two it lets me shift into fourth no problems.
Opinions?
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
2002 Chevrolet Impala
I had a similar problem with my shifter when I first put it in, but mine would always grind into second. Resolution... Got myself a new clutch and gave the shifter about a month of break in time. Now I can powershift every gear like butter.
MM's Orangest
2004 Mach 1 Mustang
I'm not powershifting at all. I was thinking I need to make the shift a little longer. Daily driving though the car runs great.
Mine did the grinding even when just shifting fairly fast at high rpms. Not speed shifting or powershifting. I was just stating after I replaced my clutch and broke my shifter in the problem was solved, thus resulting in perfect powershifts.
MM's Orangest
2004 Mach 1 Mustang
Gotcha. It's not grinding when I try to put it in gear though. I get it to the stop point and I take my hand off/release clutch. Only problem is when I take my hand off it goes back to neutral. Like you said it probably just needs time to sink in.
fourth gear synchros?
my cousins mach did that only it did it in third
2004 Black Mustang GtWhen I see a 5.0...I respect my elders. |
check the stop bolts. - and shifters dont "break in"
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
#8 | |
![]() Also, if the stop bolts weren't adjusted right would he be having problems with 2nd also??? If your stop bolts do happen to be the problem... remove them. The 3650 has stops built into the tranny. |
#9 | ||
#10 | |||
¡ʇsnq ɹo uʍop ǝpısdn
I might be mistaken but i don't think i am
the T-3650 has a built in stop already so you should be good to remove the stop screw... i might be confussing the 3650 and 56 but i don't think i am
48.47@ 12.58
^your right
the t-3650 has internal shift stops. you should take the stops out of the shifter completely.
#13 | |
#14 | |||
MM's Orangest
2004 Mach 1 Mustang
Sorry to burst your bubble guys, but one of three things happened tonight when I took out the stops.
1. Shifts got really friggin sloppy. 2. Touched the screwdriver to the wire for the power jack right infront of the shifter and blew a fuse. 3. Fourth is still getting thrown out. To top the night off I got beat by a guy running some hellacious turbo or he sprayed when I got into fourth.
Threads Similar to: Shifter Problem
| MGW shifter | AFtriathlete | Parts | 15 | January 13th, 2011 12:57 AM |
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| mgw shifter | SilverGT04 | 99-04 | 28 | September 20th, 2007 01:25 PM |
| problem getting shifter out of park! | 99greenmachine | V6 Mustangs | 2 | July 6th, 2007 11:18 PM |
| Remote Shifter... Known Problem? | cjjreed | 2005 - 2010 | 13 | October 19th, 2006 12:47 PM |
