window switch?
Old November 4th, 2007, 10:34 PM   #1
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
window switch?
how do i know if my pass side window switch is bad, it will go up an down when controlling it from the drivers side,so i know its notthe motor,an just the other day i had my hand on it while i was in the pass side an it rolloed down but never worked since then,could it be bad.....any ideal
Old November 4th, 2007, 10:52 PM   #2
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
that would be the only thing i would think of if it still works from the driver side
Old November 4th, 2007, 10:55 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
pull the panel and use a test light.
Old November 5th, 2007, 06:21 AM   #4
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
I had the same problem. It was the switch. They are easy to change. If I remember correctly they're about $20 at Ford.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 5th, 2007, 06:32 AM   #5
yojoe600's Avatar
yojoe600 will become famous soon enough
i had mine go out about a week ago and i pulled off the panel and messed around and it started working again.
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
Cat Club Co-Founder
Old November 5th, 2007, 06:53 AM   #6
Baby96's Avatar
Baby96 is on a distinguished road
I had the same problem a few weeks ago...first with the doorlock then the powerwindow..and also on my previous mustang.
Seems that the switch that is not used regulary goes bad first.
I was a bit tired of replacing the switch so i used electrical cleaner to clean it...and..it is working again...maybe you can try that before buying a new one....hope it works for you also
Old November 5th, 2007, 06:03 PM   #7
00redgt's Avatar
2000 mustang gt
iTrader: 5 reviews
i used a test light an one of the wires have power, an every time i try to cross one over to see if the window will move it sparks
Threads Similar to: window switch?
rpm window switch. mustangrebuilder Audio/Video 0 September 18th, 2007 08:58 PM
rpm window switch. mustangrebuilder 2005 - 2010 0 September 18th, 2007 07:37 PM
window switch barksdaleammo General Tech 31 May 23rd, 2007 09:33 PM
Wiring window switch Timber 99-04 11 March 22nd, 2007 07:26 PM
