Fuel Injectors
Old November 6th, 2007, 11:35 PM   #1
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Fuel Injectors
A few questions.
I'll be putting some nitrous on over the winter, 50-75shot. Do I need fuel injectors (I'm sure they won't hurt if not necessary?) And, does it matter what size? ie 60lb injectors ok for light power or do you need around a 30lb for lighter until you get more power then upgrade?
Anything else I need to be shopping for to prep for it? MAF?
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old November 6th, 2007, 11:51 PM   #2
xx9gt6xx is on a distinguished road
Send a message via AIM to xx9gt6xx
With a 50-75 shot you should be okay. You'll need injectors and a fuel pump if your going to run 100+ safley. I think they make them in 36 pound per hour? I could be wrong, but I know it's 30 something and that should be good for 100+ shots. You won't need to upgrade your MAF unless you go w/ bigger injectors but you should be fine w/ the stock ones if your only looking at 50-75 shot...
...Modded 1996 Ford Mustang GT... SOLD!!
...Modded 2001 Ford Mustang SVT Cobra... SOLD!!
Now...
...Modded 2003 Ford Mustang SVT Cobra, Anniversary Edition..
www.cardomain.com/id/po1snd_u
Old November 7th, 2007, 08:31 AM   #3
finaly03vert's Avatar
03 gt vert
lights cant time it
finaly03vert is on a distinguished road
i was under the inpresion that with my wet kit i dont have to run larger injectors. it taps into the schrader valve and sprays extra fuel in through the other side of the plate. i havent thought about it since i put it on
NX EFI plate 250 jetcustom tune Eibach Pro-Kit Magnaflow cat back high flow cats, 3:55s, ported and polished heads, comp cams, forged pistons/ rods
Curently building up 03 mach block w stage 3 port job. look for twins and more n2o
Old November 7th, 2007, 08:32 AM   #4
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
Fuel pump is recommended, but not injectors. I have a 100 shot on my car and with the stock pump, i was running at 98.7% capacity at WOT.
SVT focus fuel pump will do you fine.
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Threads Similar to: Fuel Injectors
Fuel Injectors/fuel pressure 00silvergt 99-04 4 August 2nd, 2007 09:54 AM
Fuel injectors ByPopularDemand V6 Mustangs 10 June 23rd, 2007 10:09 PM
Fuel Injectors Euroeater95 94-95 5 June 21st, 2007 11:02 AM
Fuel injectors ssdell3 99-04 36 June 20th, 2007 10:56 PM
fuel injectors scubasteve041186 V6 Mustangs 7 January 24th, 2007 02:44 AM
