A Question About Prochager With High Compression
is it true that prochargers like high compression? if it is... why? i no using a whipple is bad for high compression...i dont get it? just want to understand thanks!
Not sure where you got that one, but Prochargers like any other F/I system need low compresion.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
#3 | |
2002 Chevrolet Impala
This little read might help a bit... http://www.motorsportsdigest.com/tech/forced2.htm |
The Mean Green
Boost = low compression
#5 | |
![]() 2004 GT Boosted by Vortech |
Proud American
but boost really likes compression, stock moyors dont like both. You will make more power with a high comprssion motor and blower and can do it safely with race gas, and forged inturnals.
¡ʇsnq ɹo uʍop ǝpısdn
i have always been told run a lower compression ... around 8.5-9 when boosting ... on the other hand... if you have a strong motor and a bottle ... you can crank that compression out the ass... 11 and up if you wanted
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
cylinder pressure! the roots and screw blower almost instantly deliver full boost. instantly creating higher pressures. a centri is a little more forgiving since the boost is not all or nothing. you can run a little higher compression and get away with it since timing and fuel tables are adjustable through the rpm range. cyinder pressure will still be high, but can also be tuned out if everything is done properly.
right on buddy, lots of misinformation in this thread, the more compression and boost you run, the more power youll make, but it takes great gas and a tune thats spot on. its true that centri blowers like more compression than the tqin screw blowers. weve ran the centris on motors up to 10.5:1 and never had any problems. your safe to run a procharger on your car, but i would suggest looking into paxton novi 2000 for your car
Proud American
agreed paxton Novi 2000 FTW!
And yes too man people dont understand that to make power, you need more air, higher octane fuel, and cooler air temps. The problem is that stock rods, pistons, and crank do not enjoy the higher pressures, with out pulling a bunch of timing or running 116 octane race gas.
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
The reason that people run less compression and more boost is because the more boost you can get, the more the motor will be helped out on the intake stroke by the blower. That is why a blower makes HP- it creates loads of compression on the firing stroke by packing the cylinder with more air and then pressurizing the intake stroke as well. However, by adjusting fuel octane and timing, more boost can be run even with high compression.
mm's nitrous mod
2000 mustang gt
less sylinder pressure will be more forgiving on pump gas. the more you start pushing the motor the higher the octane will have to be used. then streetability will start to become a factor. that is another reason that the centri's will be a little more forgiving too.
The Mean Green
You better have a far from stock motor to run 10.5.1 or more with a charger. the lower the compression, the most boost you can throw at it. These motors arent very good N/A a.k.a high compression.
2001 Mustang SVT Cobra
Again, the tune makes it or breaks it. If you can do a 8:5-1 or 9, you can safely run a pro charger @ 10+ lbs of boost on pump gas and still make good numbers, provided that you have a motor that can handle it.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
whats wrong with making more power with less boost?
So how long do you think the rings will last with high compression and 10-12 pounds of boost? And I'm not sure we're talking about a 100,000 mile pump gas street driven car here? We use to run our 300ZX Turbo race car under these stresses and we were going thru the motors every 2 races (Endurance road racing). So, if we're talking race cars/motors here, then answer would be different.
Threads Similar to: A Question About Prochager With High Compression
| is 10.5:1 compression too high for a supercharger? | 94' Cobra 351 | General Tech | 33 | May 5th, 2008 08:05 PM |
| High vs. Low Compression | 87StangLX | General Tech | 14 | November 17th, 2007 10:42 PM |
| High Compression and FI | blk98gt | 96-98 | 6 | July 3rd, 2007 10:27 AM |
| compression too high for a supercharger? | 94' Cobra 351 | Drag | 3 | January 10th, 2007 11:05 PM |
| Question On Compression | chadjones99 | 5.0 Mustangs | 4 | September 12th, 2006 11:24 AM |
