Roush Diff Cover Girdle Issue
I installed a Roush rearend girdle cover a couple of months ago and it continues to leak gear oil. It appears to be leaking thru the holes for the support screws that go thru the cover. I then sized up a couple of copper washers and installed them underneath the jam nuts on each side. Still no luck, it still leaks. Anyone have any experience with these and have a remedy to cure the leaks? Thanks in advance.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
Anyone?
did you torque them down correctly. is it used. maybe just use some gasket glue.
48.47@ 12.58
sounds like a bad gasket.
you need to pull the cover and make a new gasket.
48.47@ 12.58
it's supposed to be around the entire diff plate.
it was probably tightened down wrong. you need to let the gasket get tacky before you hand tighten it. then wait another half hour or so before you break out your ratchet set.
#7 | |
i thought he said it was leaking through the suport bolts? how would the diff gasket cause that? |
48.47@ 12.58
unless I am mistaken I believe that he is talking about the bolts that "bolt" the diff cover in place.
the only other holes i could think of are the drain/fill plugs or the rear seal.
i think hes talking about the bolts that preload your maincaps. its a diff girdle not just a diff cover
48.47@ 12.58
he only bought the cover.
#11 | |
48.47@ 12.58
girdle cover *
48.47@ 12.58
is this what you bought?
no its a roush one stupid
It is a Roush unit and it is leaking thru the girdle support studs that go thru the cover. The cover gasket is not what's leaking. Yes, it is torqued properly. It is just bleeding thru the holes slightly. It is similar to the one in the pic except the studs/bolts are not counter sunk.
Threads Similar to: Roush Diff Cover Girdle Issue
| Rear diff girdle support system | 99spaded | 99-04 | 5 | July 22nd, 2007 08:19 AM |
| Axle Girdle | Blackblurr_00GT | 99-04 | 5 | June 27th, 2007 09:58 AM |
| TA Girdle | Jorge | 96-98 | 1 | June 7th, 2007 11:30 PM |
| Differential girdle | DaemonJ | V6 Mustangs | 8 | February 6th, 2007 10:57 AM |
