Stuck on which way to go - Forums at Modded Mustangs
post #1 of 20 Old March 28th, 2014, 10:46 AM Thread Starter
Built Tough
MuscleCars's Avatar
Talking Stuck on which way to go
I really need to make up my mind on which way to go with this NA build............ purely a street car it will Hardly yo Never see the track
Big Bore Boss Block/Stroked 323ci
2V: ported tfs 195cc heads, port matched vic jr and elbow, really wanting an oval tb so it'll breathe more, custom cams, etc
4V: ported 4v heads, probably ported cobra intake, oval tb, custom cams, etc
5.4L Block 330-331ci
2V: same ported tfs heads, 4.6 to 5.4 adapters with same ported intake, custom cams, etc
4V: same ported heads, hoping to use the super cobra jet na intake and tb, custom cams, etc
5.8L Block 351-358ci
2V: same as above
4V: same as above
What are you guys thoughts on this?
MuscleCars is offline
post #2 of 20 Old March 28th, 2014, 12:08 PM
WrenchThrower's Avatar
I would go the most cost effective route since no racecar, but thats just me.
Really doesn't matter, it will be fast/faster/fastest set up. And fuel mileage will be crappy/crappier/crappiest respectively.
|4.10's|CMS Stage I cams|70 tb/plenum|O/R X pipe|SLP Power Flow cat back|93 octane tune|SFI U/D's|FRPP B springs|Weight Redux|
WrenchThrower is offline
post #3 of 20 Old March 28th, 2014, 12:12 PM Thread Starter
Built Tough
MuscleCars's Avatar
Not really worried about fuel mileage with this car lol, but that's what I was thinking,
post #4 of 20 Old March 28th, 2014, 08:05 PM Thread Starter
Built Tough
MuscleCars's Avatar
70 views and 1 person, cmon guys and gals, I'm sure some of you have some insiight on this
post #5 of 20 Old March 28th, 2014, 08:30 PM
04darkshadowgreygt's Avatar
Not sure. They all sound good.
I'd probably go with the one that you can find the most parts for. Headers for one.
Otherwise you'll be doing a lot if modifying.
Sent from AutoGuide.com App
BBK CAI, MAF & SHORTIES, MAC O/R H, FLOWS, STEEDA TRI AX, FRPP 3.73, MM CC PLATES & RLCA's, STEEDA BUMPSTEER & X2's, FRPP B SPRINGS & RUCA's, KONI STR.T DAMPERS, STIFFLERS MATRIX FLSFC's, COBRA STEERING RACK 17X9/10.5 SUMITOMO 275-315
04darkshadowgreygt is offline
post #6 of 20 Old March 28th, 2014, 08:43 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Your about to spend ALOT of money!! if your goal is to be faster then the next guy your going at this wrong. BUT if your like me and just want what you want then I suggest going the 4V route with ported heads, custom cams with the largest bore and stroke you can throw at it safely. Going NA forget the 2V heads they will never flow enough to make you happy.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
11.50@121.77@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #7 of 20 Old March 28th, 2014, 08:54 PM
04GT_armyMAN's Avatar
All sound good but it is gonna be purty costly.. I'm just guessing u already knoe that tho ... keep us posted on the Decision tho!
04GT_armyMAN is offline
post #8 of 20 Old March 28th, 2014, 09:18 PM Thread Starter
Built Tough
MuscleCars's Avatar
Yes I'm just like you so to say, I was going to go fi, kenne bell or twin turbo, but told myself that I really did not need that as it'll never see the track to fully use it, and the thoughts of high compression na build cam to mind, not worried about being faster than the next guy as I once was, those ported 195cc heads should be more than amazing without ruining them with over porting, cant really say which way I'm leaning more towards
---------- Post added at 08:06 PM ---------- Previous post was at 08:05 PM ----------
Definitely going to cost me but oh well, for what either set up will run me I could build 2 fi setups almost
---------- Post added at 08:18 PM ---------- Previous post was at 08:06 PM ----------
Also was suggested going the coyote route, and using the scj intake and tb highest compression on pump 93, and I was told that the 5.4 with the scj intake would not fit under the stock hood, if that be the case I have no problem with the 00 cobra r hood, just don't have for the extra cowl hoods
post #9 of 20 Old March 29th, 2014, 01:45 AM Thread Starter
Built Tough
MuscleCars's Avatar
I doubt I go the coyote route, even tho it will be nice as hell, unless I could use the coyote bare block and not have to worry with all that is necessary for the swap, but I highly doubt it
post #10 of 20 Old March 29th, 2014, 02:06 AM
US Air Force (retired)
Eagle2000GT's Avatar
I wish you luck. You must have a lot of money to spend because NA is a very inefficient choice. Again, good luck... you will need it.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Also own: 1997 Harley FXDWG, 1998 F-150, and 2002 Corvette LS1
Eagle2000GT is offline
post #11 of 20 Old March 29th, 2014, 02:06 AM
Feb '14 ROTM
BlackWidowStang's Avatar
My vote is Boss block.
504/433
BlackWidowStang is offline
post #12 of 20 Old March 29th, 2014, 02:13 AM Thread Starter
Built Tough
MuscleCars's Avatar
Been saving for awhile, yea I know its not the most cost effective way for power but whatever
---------- Post added at 01:09 AM ---------- Previous post was at 01:08 AM ----------
That's what its looking like or the 5.4
---------- Post added at 01:13 AM ---------- Previous post was at 01:09 AM ----------
On top of that ima sell the built block and the vortech setup
post #13 of 20 Old March 29th, 2014, 02:25 AM
SBF. Get a 351w block and do a 408 stroker.
gravik is offline
post #14 of 20 Old March 29th, 2014, 02:49 AM Thread Starter
Built Tough
MuscleCars's Avatar
Lol.... haha, ill leave the pushrods where they're at, love how they sound and all but not my thing
post #15 of 20 Old March 29th, 2014, 02:59 AM
4 cam 4 life
NeverEnuff's Avatar
Actually NA is the MOST efficient choice. THey are more efficient than any boosted motor out there. The more you make NA, the way more you will make IF you put boost on it.
To the OP...make up a ET goal for what you want, and then you can decide how light you want the car and how much you will need to get there. If you just want bragging rights on power...then get the most cubes you can get, and get the best heads out there..ie Ford GT/GT500/Cobra R heads, get them ported and run a sullivan intake. But look to spend around 15-20k easy if you want the bassest one out there...
89 Coupe-Worlds Fastest NA Modular build in progress
http://www.moddedmustangs.com/forums...lar-build.html
01 Lightning-Ported Eaton, Comp 278s, Exhaust, daily
NeverEnuff is offline
post #16 of 20 Old March 29th, 2014, 03:14 AM Thread Starter
Built Tough
MuscleCars's Avatar
Agreed with you on the most reliably efficient way, but aa far as cost goes...... nahhhh, it doesn't have to be the baddest, I just want it to run strong and be fun car, as far as an ET I'm not sure at all being, this will never really see the strip, still have to decide on if it'll be 2v to keep the architecture of the car or if ima build the 4v, but either way I know I'm going to be happy with it, I mean I'm not trying to set records or anything
I've thought about the GT heads, not the cobra rs or even the gt500, if I go 5.4 I may have it bored to a 3.7" and run one of those heads I'm not sure
A 5.4 bored and sleeved with one of those heads ported, custom cams possibly the scj intake would be Stout as hell
post #17 of 20 Old March 29th, 2014, 09:06 AM
95mustangGT/SVT's Avatar
Your car will be just as much fun to drive with a 4.6 and blower/turbo as a bad ass NA motor. I have a 400 CI SBC in a 1942 Jeep willys making well over 400 HP NA and a 383 in a 1974 corvette making 457 HP NA, but my boosted 4.6 is just as much fun. If you are staying NA there is no replacement for displacement. Remember that with a solid NA build you should be able to get roughly 1.15 HP for ever CI. You certainly can make more than that ratio but that is on par without dropping cash like it's your job. Therefore, I would go the 5.8 route.
408 RWHP/415 RWTQ
95mustangGT/SVT is offline
post #18 of 20 Old March 29th, 2014, 12:42 PM Thread Starter
Built Tough
MuscleCars's Avatar
Yea true I could have a fun car with a blower or turbo, but id end up going overboard! I know me, and there is some talk about getting a 5.4 block and sleeving it and getting it to a 5.8
---------- Post added at 11:42 AM ---------- Previous post was at 10:58 AM ----------
Wish I could get the new ford 5.8l block for cheap ever I've seen is 4k+ just for the block itself, probably because it's an aluminium block,
post #19 of 20 Old March 29th, 2014, 01:26 PM
GM2Ford's Avatar
+1 to everyone that is saying it will cost tons of money...
Here is a dyno graph picture of my friends N/A 01 Cobra. He has an aluminum 4.6L that was Bored & Stroked, runs on 93 Octane @ 12:1, with ported GT40 heads, custom headers for his engine, that's all I recall about now. I don't remember his full mods & build list to his motor but it was fucking huge.
So far the most power he made was at 644rwhp & 606rwtq @ around 6k rpm, his motor is made to rev to 8,500 rpm... but he under anticipated the power & his intake was restricting air flow, so you can see it stopped making power around a bit past 6,000 rpm.
He spent over $40,000 building his car, that's including his trans, built irs & suspension. Most of which he said was into his motor.
1991 Camaro RS - Sold
1989 Iroc-Z28 -Sold
1999 Mustang GT - Under Construction
1993 Ford Escort - Sold
http://www.moddedmustangs.com/forums...v-4v-swap.html
^1999 GT w/ 2001 Cobra Motor w/ 2004 Eaton Swap^
GM2Ford is offline
post #20 of 20 Old March 29th, 2014, 01:39 PM Thread Starter
Built Tough
MuscleCars's Avatar
Bow down to him! I by no means will spend that in a a motor, I salute him and that is amazing! Ill prolly be at 12:1 with a similar build but NOWHERE near 40k
Human Verification
