Rear End Problems
Old November 9th, 2007, 04:12 PM   #1
1965 Ford Mustang
01dutchGT is on a distinguished road
Send a message via AIM to 01dutchGT Send a message via Yahoo to 01dutchGT
Rear End Problems
I had my MM full length subframe connectors welded in today and when if was up on the lifts, I noticed rear end fluid all over my mufflers. My friend is a ford mechanic and he looked at it and said that i had to much play in the drive shaft and may have to rebuild the rear end. What exactly does this mean. I just 4.10 gears put in and there isnt any wine and works perfectly. I just think that the bearings and seal are bad. Any help would be great.
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old November 9th, 2007, 04:14 PM   #2
Proud American
MustangMatt96GT's Avatar
Its just a bad pinion seal most likely!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old November 9th, 2007, 04:16 PM   #3
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
+1, is it leaking from the front of the rearend? where the driveshaft goes in?
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old November 9th, 2007, 04:33 PM   #4
1965 Ford Mustang
yes i think so. If its a bad seal, will that make the drive shaft loose or is it suppose to move alittle.
1965 Mustang
Old November 9th, 2007, 04:44 PM   #5
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
my car is terrible about tearing up pinion seals...
I've put 4 in since last september! finally have it fixed for good this time.... But I would imagine if you just had gears put in, they would have replaced the pinion seal? Were you able to trace about where it was coming from... and about how much slack do you have in the driveshaft?
Old November 9th, 2007, 05:00 PM   #6
1965 Ford Mustang
The guy said its moving to much. I felt it and it can wiggle about 1/8 inch in each directions or somewhere in that range. Ill have to look exactly where its coming from but i know its from somewhere in the front where the driveshaft meets up. I have a feeling its the bearings but i wont have to replace my gears right because I know there installed right and work fine. Now the place could have screwed up on the seal but im not sure.
1965 Mustang
Old November 9th, 2007, 05:30 PM   #7
Achieving more N/A power!
gills99stang's Avatar
When this baby hits
88 miles an hour...
gills99stang will become famous soon enoughgills99stang will become famous soon enough
Send a message via AIM to gills99stang
I would guess the seal first, but I suppose the bearings could be an issue.
Brendan
'99 Mustang GT [ 318 rwhp N/A ] - SOLD ()
'04 F150 XLT SuperCab
Old November 9th, 2007, 06:19 PM   #8
1965 Ford Mustang
I thought that the ford rear ends were really strong so im not thinking its the bearings but hopefully it will only be seal. If im going to have rebuild it, what would i need to get to make it stronger.
1965 Mustang
Old November 9th, 2007, 07:33 PM   #9
2kGT's Avatar
2kGT has a little shameless behaviour in the past
My rear flings fluid all over the mufflers too -my pinion seal is leaking, just dont feel like fixing it - its a b1tch. Could be a bent driveshaft that causes these leaks.
Accufab 75mm tb & plenum
MRT h-pipe
Flowmaster catback
FRPP king cobra clutch
FRPP aluminum driveshaft
FRPP 4.10 gear
TA Perfromance girdle
Steeda tri-ax shifter
Moser 31 spline axles
FRPP C Springs
Old November 9th, 2007, 07:48 PM   #10
steveduvall is on a distinguished road
Crush sleave
Well I dont know who did the install for your 4.10's but it sounds like they didnt get the setup right, there is a crush sleeve on the pinion that requires when installed to be crushed to a certain depth and this is done by the nut on the pinion flange, its quite obviouse due to the oil leak, you will need to have a new crush sleave and new pinion seal! I would recommend that you take this to a ford dealership to be done because they have the correct tools and it will be done correctly! Also this will not cost as much as one would think at the dealer.
Old November 10th, 2007, 12:51 AM   #11
13.00 @ 105
FYI - The leak may look really bad, but a small drop goes a long way....
still something to be fixed, but its probably not near as bad as you think...
Old November 10th, 2007, 01:12 AM   #12
superbeef1000's Avatar
Smile
+1 for the pinion seal
Old November 10th, 2007, 01:45 AM   #13
thenewGT350's Avatar
thenewGT350 is on a distinguished road
Send a message via Yahoo to thenewGT350
I just installed a Detroit Trutrac in mine and had the same problem. I went 2 months and finally just replaced the seal. but just cus it leaks doesn't mean anything else is bad. if it was a bearing you would deffinetly hear something. you could logically hold out as long as you want, just keep an eye on the fluid level, or your bearings will go bad, or worse sieze up.
Old November 10th, 2007, 08:39 AM   #14
JohnC's Avatar
1997 Mustang GT
13.56@102.94
JohnC is on a distinguished road
I had my 3:73's installed at Two Rivers Ford in Donelson TN and they screwed mine up.
That said, I wouldn't recommend just any Ford dealer or shop to do the work. I'd check around and see who all has gears done properly and ask what shop did the install.
1997 Mustang GT
Aluminum Block PI swap & 4R70W to TR3550 swapped.
Best 1/8: 2.04 60ft 8.74@81.85 &
Best 1/4: 2.045 60ft 13.56@102.94
all on stock 245-17's
My Garage
Old November 10th, 2007, 09:45 AM   #15
1965 Ford Mustang
Eaton Posi Limited Slip 8.8in 31 Spline Differential.... Would this work with my car and would it make it stronger? Thanks for all the opinions on it, ill probably take it to the ford dealer to have them look at it today. How much you think it would cost to get new crush sleeve and seal...Like i said there isnt any wine with gear and drives perfect with no problems just some fluid out the back so i have a feeling yall are right and its just a small drop.
1965 Mustang
Old November 10th, 2007, 01:51 PM   #16
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
There is a replacement for the crush sleve, (it's not a crush sleve) you'll have to ask maybe JEGS or MMR what it is called, get your drive shaft check and replace the pinion seal
Old November 11th, 2007, 11:44 PM   #17
as for the eaton posi, you can get one that will fit, but the best on the market is the deroit tru trac. its a gear type instead of the clutch type and can handle up to 900 ft lbs. of torque. this is the one that all those rock crawler guys use and Nascar as well. any other type is sub-par.
the Tru trac will run you about $500 though but its money well spent.
I got posi WOO-HOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old November 12th, 2007, 09:59 AM   #18
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
Go here for a true trac. TRUE TRAC-8.8 31 SPLINE - GEARS, LOCKERS, INSTALL KITS, FORD 8.8"
This is a 31 spline one but if you go back one page you will see the 28 spline one.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Threads Similar to: Rear End Problems
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 22 April 25th, 2011 03:59 PM
Rear side seat belt problems Archy88 General Tech 1 October 9th, 2007 03:09 AM
V6 Problems Bies08 V6 Mustangs 16 March 22nd, 2007 12:59 AM
Rear Rotors and Rear Axle rondaw3g0410 99-04 1 September 6th, 2006 10:00 PM
A few problems... Stan27 Audio/Video 8 August 17th, 2006 01:14 PM
