Setup question
Old November 9th, 2007, 11:40 PM   #1
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
Setup question
Ok so long story short...after i get out of the air force, i plan on building up my car. This is going to be a few years out, but i want to be well researched before i do my next setup.
My last setup on my 04 gt was a P-1SC, 42# injectors, svt focus pump, 4R70W, MAFia, 3.73 gears, flowmaster 40's mufflers.
I'm back to a "stock" configuration for right now...stock injectors, stock maf, but running air intake through sc not hooked up (i know dumb, but looking for a cheap intake) I will not run the s/c until i go forged since i've already blown one motor.
I have a stock block that i plan on boring over 20 then putting a MMR rotating assembling in it...then maybe running stock heads with blower cams or maybe more not sure yet. Probably keep the car a 2v car since i don't plan on going over 500whp
So two main questions i have (please back up with stats if ya have them) 1. Keep the P1-SC? 2. Carb or fuel injected?
Thanks,
Bob
Old November 10th, 2007, 12:00 AM   #2
Proud American
MustangMatt96GT's Avatar
fuel injected, and set up to a novi 2000. you wont regret it.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old November 10th, 2007, 12:20 AM   #3
dude496's Avatar
04 Mustang GT
nah wont go with a novi 2000...if i stick with centri i'll just stick with procharger...wondering about a kb though
Old November 10th, 2007, 10:58 AM   #4
HessiaN257's Avatar
13.9@101
HessiaN257 is on a distinguished road
I'd keep if fuel injected. a KB is a great supercharger, its a twin screw so it makes almost instant boost. You will love this supercharger going around the streets and what not. As for the prochargers, they will take longer to make full boost, but they will make more power in the 3000 and up RPM range.
13.9@101 before some mods
Old November 11th, 2007, 02:31 AM   #5
dude496's Avatar
04 Mustang GT
I'm not planning on drag racing this car every weekend....So since i have the Procharger already, maybe i should just do a forged small block...and build up the tranny to support
Old November 11th, 2007, 10:48 AM   #6
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
I did the reserch on the KB and webt with it best kit I have ever bought. I had the motor built around the SC. Not cheap but damn well worth it!
Old November 12th, 2007, 08:39 AM   #7
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
How much money to you have to spend? Set an objective..500 rwhp, then decide what you need to get there. I personally am not interested in change for change sake.If the Procharger will get you there then use it.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 19th, 2007, 10:46 PM   #8
dude496's Avatar
04 Mustang GT
A "plan" for hp is kind of a funny thing...its just like working out...yeah i ran this far so why not run a little farther...yeah i lifted x lbs, so why not try to lift a little more...but yeah my plan right now is for around 500 whp. I want to keep the rest of the build to under 10k. Total price will include engine, suspension, and trans. So besides the P1SC and gears it will be a total build up. I have a block, and machining will be around $250.
Old November 19th, 2007, 10:55 PM   #9
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
keep it fuel injected, easy to work with and everything in the car is already set up for it. it doesnt take much to make 500whp, the p1sc will be able to get there without much problms. if you were to keep around a stock compression ratio and all supporting mods, the p1sc will get it there at around 15psi.
Old November 19th, 2007, 11:26 PM   #10
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Put a KB on it with TT Hellions. Oh the power!
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Threads Similar to: Setup question
The new setup! Tony_90fox The Clubhouse 6 August 7th, 2007 09:57 PM
carb setup question 86gt5liter 5.0 Mustangs 2 May 15th, 2007 05:16 PM
EFI Setup litlegto 5.0 Mustangs 4 October 24th, 2006 12:09 PM
The big question : What kind of exhaust setup should I have? Chris02 99-04 6 October 23rd, 2006 01:04 AM
need help on SC setup 96stangboi 96-98 1 October 19th, 2006 01:22 PM
