Differential
Old November 10th, 2007, 12:34 PM   #1
1965 Ford Mustang
01dutchGT is on a distinguished road
Send a message via AIM to 01dutchGT Send a message via Yahoo to 01dutchGT
Differential
Whats the best differential for my mustang. I already have 4.10 but kinda want to put a posi in it. Any suggestions
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old November 10th, 2007, 02:46 PM   #2
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
EATON and 31 splines
Old November 11th, 2007, 01:32 AM   #3
brianm's Avatar
2011 ram 1500 hemi
brianm will become famous soon enoughbrianm will become famous soon enough
detroit true trac is a wicket lsd
vmp500 hp. jba lts. powerhouse d/s Sold
Old November 11th, 2007, 02:06 AM   #4
1965 Ford Mustang
thanks man, now what all would i have to do to get this to work. would i need new axles and/or new gears or would my gears and axels work fine
1965 Mustang
Old November 11th, 2007, 03:37 AM   #5
brianm's Avatar
2011 ram 1500 hemi
don't waste money on axles, unless your on slicks. your old gears are fire just get new bearings, its a good idea.
Old November 12th, 2007, 09:32 AM   #6
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
You already have a posi, or a limited slip differential.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 12th, 2007, 10:25 AM   #7
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
+1! The eaton LSD clutches will wear out and you'll be replacing them. Now I have heard some people say the true tracs are a little noisey and others say they are quiet as stock, but the true trac is your best bet. If you plan on running slicks or drag radials and plan on hard launches then I would step up to the 31 spline axles and true trac diff. If not they do make a 28 spline true trac. It's up to you and your driving style. I'm going with a supercharger down the road for sure and drag radials so I am building my rear end up...axles, diff, 3.73s, girdle, and a complete rear end rebuild kit. If you want a good price with free shipping on a true trac diff checkout this page.
TRUE TRAC-8.8 31 SPLINE - GEARS, LOCKERS, INSTALL KITS, FORD 8.8"
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old November 12th, 2007, 10:29 AM   #8
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
which page black???? no linky
Old November 12th, 2007, 10:34 AM   #9
Fixed it.
2001 Bullitt #5069
Old November 12th, 2007, 10:40 AM   #10
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
iTrader: 10 reviews
suhweet
Old November 12th, 2007, 01:04 PM   #11
1965 Ford Mustang
i like the tru track. Now when going to install it, what all will i have to do cause i just got my 4.10 frpp gears installed and dont want to loose those.
1965 Mustang
Old November 12th, 2007, 01:12 PM   #12
You won't lose you gears from installing a diff. Just make sure that you either oder the 28 or 31 spline diff depending on if you are keeping the stock axles or upgrading to the 31 spline axles. If you purchase a master kit it should have everything you need.
2001 Bullitt #5069
Old November 12th, 2007, 01:18 PM   #13
1965 Ford Mustang
Im going to go with the 28 spline and what all does the master kit come with and is this something i could install myself or should i let a shop do it.
1965 Mustang
Old November 12th, 2007, 01:33 PM   #14
Unless you know how to do it and have the right tools have a shop do it. If you have a shop do it they might have the right kit to install everything so you don't have to worry about it.
2001 Bullitt #5069
Old November 12th, 2007, 01:34 PM   #15
1965 Ford Mustang
ok cool thanks man
1965 Mustang
Old November 12th, 2007, 01:37 PM   #16
Not problem. If you plan on going FI at all or doing hard launches I would suggest going with a 31 spline setup and doing it right the first time. I'm not telling you how to mod your mustang I'm just looking out for your future interests that may come along.
2001 Bullitt #5069
Threads Similar to: Differential
differential swap? Stang6899 V6 Mustangs 14 October 23rd, 2007 07:28 PM
differential upgrade mach1power 99-04 4 March 17th, 2007 08:33 PM
Help! Differential flames_blue V6 Mustangs 5 February 5th, 2007 03:55 PM
Differential whitb610 99-04 5 November 4th, 2006 10:49 AM
Differential Drgnracin72 General Tech 4 September 19th, 2006 10:06 PM
