Gauges For A-Pillar
Old November 11th, 2007, 02:32 PM   #1
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Gauges For A-Pillar
I'm throwing an A-Pillar on my Mach. I'll most likely being putting a Zex kit on it so one of the 3 slots will be for bottle pressure. The other two I was thinking Oil Pressure and Air/Fuel Ratio. Any other ideas?
Btw I was looking at the gauges from this website
Tinted 7 Color Air/Fuel Gauge - GS-T702
Does anyone have anything good/bad to say about them?
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old November 11th, 2007, 02:39 PM   #2
2003 Mustang GT
03TropicGt is on a distinguished road
Talking
if your going to put in a air/fuel gauge make sure its a wide band
Old November 11th, 2007, 02:41 PM   #3
Proud American
MustangMatt96GT's Avatar
yeah PM hmusn for a wide band he has a hook up!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old November 11th, 2007, 02:45 PM   #4
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
I liked these because they are tinted when the car is turned off. I know it really doesn't make a difference but they seem pretty cool nonetheless. Would there be any way to see if these are wide band other than emailing?
Old November 11th, 2007, 02:48 PM   #5
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
wow! i really love the tinted also. Well i know what the next thing i'm getting is lol.
Old November 11th, 2007, 02:56 PM   #6
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Those are narrow band gauges in the link you put.
basically it's a light show.
If you want an A/F gauge you need to get a Wide Band 02 set up with a wide band 02 gauge.
there is a reason that gauge is only like $50.00 man.
You pay for what you get.
I can get you a PLX
wide band 02 set / gauge.
your bottle should already have a mini pressure gauge on it so I wouldn't run a gauge on the pillar for it.
on the pillar for an N/A car I would run
A/F
Oil Pressure
Fuel Pressure
Old November 11th, 2007, 02:59 PM   #7
Proud American
i have temp, oil pressure and a/f ( well not the a/f yet)
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old November 11th, 2007, 10:11 PM   #8
hudini is on a distinguished road
Please put in a water temp gauge. I have a tri-pod pillar on my Mach and if it wasn't for the Auto Meter water temp gauge I would have done some real damage to my engine. The cheap junk gauge that Ford gives you isn't worth the plastic they use to install it. My Auto Meter was reading critical and the Ford gauge that came with the Mach showed the needle dead center in the gauge, basically telling me the temp is no more then 200.
Threads Similar to: Gauges For A-Pillar
C-Pillar Scoops SickSixer04 Visual 11 July 29th, 2007 07:06 PM
Guage Pillar Garhfer 99-04 7 June 11th, 2007 06:34 AM
c pillar scoops chrish91286 V6 Mustangs 6 January 18th, 2007 08:59 PM
