Supercharge
whats needed to bore to a (5.0) and supercharge a mustang. 2000 GT.
You wanna swap your 4.6 to a 5.0 and supercharge it?? Right?
RLY SRS
No he means to stroke the 281CI to 302CI...
Ther are a couple of people on here that have did it... PM drgnracin72...He did his... |
Would I need to swap the whole motor or can I bore it? Its my friends car I drive an import I don't know much bout domestics.
48.47@ 12.58
you would bore and stroke it.
From oil pan up to valves, the motors are the same.
Boost gets you laid
you can get a 302 forged stroker kit for about $1750 and then get a good supercharger, with that combo you can run as much power as you can throw at it. 600+
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
99 limited edition vert
you can install a bb alum block(3.7 bore) stock stroke and have a 305ci. this setup could handle rpms better
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
Boost gets you laid
yes but it will cost you a lot more too. you can get plenty of power out of the stock 4.6 stoke as it is, i would only do a stroker kit if i was building an N/A monster.
What supercharger would you reccomend for a goal of 500+ To the wheels. Whats a good place to buy that kit?
RLY SRS
Modular PowerHouse
Check out the mongoose kits... I would buy the NOVI 2000 is you want a centri... If you want a twin screw Kenne Bell all the way... |
whats the difference?
48.47@ 12.58
where the boost hits in your rpm range
RLY SRS
How Superchargers Work
Roots - Eaton Centri - Paxton, Vortech, Procharger Twin Screw - Whipple and Kenne Bell read those and you will understand |
12.73@111.36
I like Procharger, but you can't safely get to 500 rwhp without buying forged rods and pistons. The stock rods and pistons are only good up to 420-450 rwhp. The stock crank is good to 650.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
So bottom line, stroker kit with forged rods and pistons and he wants a keen bell supercharger. I drive a eclipse and I know for our cars (DSM'S) you need a kit when your getting out of the stock turbo or out of the N/A (supporting mods) is there anything else needed right now? he has a K&N filter Cat-back flowmasters and ECU. Thanks.
If he just did the supercharger on the engine now would it really matter as opposed to doing the swap? |
Boost gets you laid
he can just put a supercharger on it and call it a day. the kenne bell kit comes with everything you need for a complete install, even the tune. but he will be limited to 9 psi with that supercharger on stock engine internals. if he did a forged kit, or forged stroker kit, he will be able to turn up the boost as high as he wants. he will need to beef up his transmission and rear end if he goes with higher boost levels
the KB 9 psi intercooled kit,is a nice kit.mine runs great on the KB tune. kit comes with everything you need except for plugs and a tube of ultrablack
Boost gets you laid
the stroker kit? i mean the aluminum shortblock..
Threads Similar to: Supercharge
| to supercharge the 6 | cgss | V6 Mustangs | 35 | May 14th, 2007 09:55 PM |
| If I supercharge.... | Stang6899 | V6 Mustangs | 19 | April 2nd, 2007 02:03 AM |
| 96 2v supercharge | G.T. Rags | 96-98 | 4 | March 21st, 2007 05:16 PM |
| What Do I Need To Supercharge | taylor96gt | 96-98 | 10 | November 13th, 2006 11:23 PM |
| Supercharge my GT? | GTSilver | 99-04 | 19 | November 3rd, 2006 01:18 AM |
