UD Pulleys
Old November 13th, 2007, 05:03 PM   #1
Monster90's Avatar
2003 Mustang GT 5spd.
Monster90 is on a distinguished road
UD Pulleys
I'm going to be buying some ud pullies in a couple of days and was just wondering how hard it would be to install them myself. Also, what tools would I need?
Accufab tb/plenum,JLT rai,Steeda ud pullies,Pro 5.0 shifter,Bassani catted x-pipe,Bassani catback,Tokico front and rear shocks,eibach lowering springs,Strange SS Street brakes,17x10.5 Nitto 555r's,black FR500's,Mach 1 grill delete/chin spoiler
Old November 13th, 2007, 05:13 PM   #2
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
UDP's are really easy to install. the only issues i had was:
1: the alternator pulley- i didn't have enough room to work on just removing the pulley (impact wrench wouldn't fit) so i had to remove the alt, then remove the pulley. not really a big deal.
2: the crank pulley- breaking the nut loose without the crank turning can be a PITA. you can leave the car in gear while trying to remove the nut, or take a floor jack and position it under the crank pulley with just enough tension on it to keep the crank from turning while you try to break the nut free.
a lot of people here will tell you to stay away from the piggyback style pullies because they're garbage. here's what i have to say about that: replacing the harmonic balancer (which on our cars is the crank pulley) can result in inadequate vibration damping. this is caused by having a smaller diameter harmonic balancer (UDP for the crank). this can lead to a harmonics problem which can result in failure of the oil pump gears. with the piggy back style UDP's, the crank pulley is bolted, or piggy-backed, onto the original crank pulley/ harmonic balancer. i personally have been running MArch piggy back style UDP's for over a year an haven't had any issues at all with them. good luck and ask if you have any other questions...
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old November 13th, 2007, 05:16 PM   #3
Resident Bubblehead
00vabchgt's Avatar
as for tools, you'll need a harmonic balancer puller. you can get one from Auto Zone or wherever. they're pretty cheap. an impact wrench will also help a lot. i also recommend about a 2 foot breaker bar to help remove the nut on the crank pulley. i'm not sure on the socket sizes for the nuts and bolts. sorry, i did mine a while back and i can't remember...
i also recommend some loctite if you go with piggy back UDP's to bolt the new crank pulley to the harmonic balancer
Military Crew
MM1 (SS)
US Navy Veteran
Old November 13th, 2007, 05:19 PM   #4
Monster90's Avatar
Thanks for all the info. Now I'm just trying to decide between the BBK or Steeda pulleys.
Old November 13th, 2007, 05:23 PM   #5
Resident Bubblehead
00vabchgt's Avatar
no prob. i hear really great things about the Steeda set. actually, i hear that about all of Steeda's stuff. you really can't go wrong.
Military Crew
MM1 (SS)
US Navy Veteran
Old November 13th, 2007, 05:23 PM   #6
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
break the nuts loose before removing the belt.... it gives a little more tension to help you out
Old November 13th, 2007, 06:07 PM   #7
2004 GT
slow....
pa.ulB is on a distinguished road
Send a message via AIM to pa.ulB
i like bbk but there all about the same, and to make it really easy use an impact gun.
2004 Crimson red GT
saleen s/c, full bolt ons
Threads Similar to: UD Pulleys
pulleys! steeda gully 99-04 24 July 12th, 2007 09:21 PM
pulleys mustang1072 V6 Mustangs 49 December 29th, 2006 02:54 PM
best pulleys for the best $$ adamo41188 Feedback Forum 0 December 27th, 2006 12:21 AM
