2000 GT
Stronger Tensioner?
K my tensioner pulley is being yanked/pulled on by the kenne bell and it rubs against the another pulley... are there stronger tensioners out there or stronger spings for it? i had one pull itself out of the timing cover before.
Running 8 rib pulleys with ~16 psi. |
can you run a hair longer belt?
2000 GT
Would longer belts help? they said they put on a smaller one and it helped... But would make sense a longer one would not put as much tension on it...
dunno man i dont run anything similar. but i was thinking you may have one on too short. therefore overloading your tensioner. maybe your tensioner is just wore out.
#5 | |
Zoolander
04 Cobra #2260/3768 1/820
Check around for stronger springs in your tensioner or see if possibly you can find a place that can make one. |
2000 GT
Its a brand new tensioner... like 2 or 3 weeks old.
Threads Similar to: Stronger Tensioner?
| Stronger Body | Wulfman | 5.0 Mustangs | 59 | November 9th, 2007 01:41 AM |
| 342 stronger than 347 | White Thunder | 5.0 Mustangs | 13 | November 6th, 2007 12:26 PM |
| Belt tensioner? | militant54 | 96-98 | 3 | October 8th, 2007 01:16 PM |
| Which pistons are stronger | wolverine8490 | 5.0 Mustangs | 13 | June 22nd, 2007 12:21 AM |
| Need stronger bottom end, tight budget, but want it right | coolridgedug | 99-04 | 8 | May 29th, 2006 04:07 PM |
