Trans Problem (First Gear)
Old November 13th, 2007, 11:08 PM   #1
brianm's Avatar
2011 ram 1500 hemi
brianm will become famous soon enoughbrianm will become famous soon enough
hi, lately i have noticed that my car i hard to get into 1st gear. when i stop at a light and try to put it in first to leave the only way it will go in is to ram it in or go to 3th first , and some times theres a clunk in the rear end right when i am putting it in gear, almost like theres something inside catching a bit. any ideas? oh its the 3650
vmp500 hp. jba lts. powerhouse d/s Sold
Old November 14th, 2007, 12:04 AM   #2
2001 Mustang COBRA
13.39@106.36
VinceSVT is on a distinguished road
that clunk in the rear end might be ur backlash in the gears in ur rear differential there kind of sloppy in mustangs and ur first gear synchro's might be damaged from making hard launches you might wanna have ur transmission looked at because i have had similar problems when i bought my 2001 cobra so i rebuilt trans.
Old November 14th, 2007, 08:05 AM   #3
brianm's Avatar
2011 ram 1500 hemi
i had the 1-2 synchro done just after i bought it. i guess its time for some more. jes i wonder how long it would last if i was pounding on it? i try to baby it most of the time. So are these trannys junk or what?
Old November 14th, 2007, 08:14 AM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
could be shift pads, fork, twisted input, clutch adjustment, syncro's, or clutch is bad.
Old November 14th, 2007, 08:25 AM   #5
yojoe600's Avatar
yojoe600 will become famous soon enough
does putting it in second then first help?
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
Cat Club Co-Founder
Threads Similar to: Trans Problem (First Gear)
Auto Trans Problem - Stuck in Park on my AOD Sir Charles 96-98 10 July 10th, 2007 10:03 PM
Trans. problem?? McCallister 99-04 28 April 7th, 2007 08:23 PM
Question on AOD Trans - No 3rd Gear....Help please!!!!! TomF514 5.0 Mustangs 4 January 7th, 2007 01:55 PM
clutch or trans problem? blackcherry90 5.0 Mustangs 4 December 8th, 2006 11:27 AM
Trans Problem 97what? V6 Mustangs 0 September 10th, 2006 06:29 AM
